Ignition timing wrong?
Old Feb 16, 2014 | 11:38 PM
ace322's Avatar
So quick question because i have searched on these message boards and cannot seem to find the answer. Does anyone know what the correct spark advance is on a 91 z28 5.0 TPI motor? My current reading while idling is 18.2* @ 703 RPM. I really need help on this issue before I start doing any other sort of work on the car.
Old Feb 17, 2014 | 06:37 AM
ex-x-fire's Avatar
Re: Ignition timing wrong?
Follow the emissions stickers direction. It has the timing spec & procedure.
Old Feb 17, 2014 | 06:47 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
The timing spec for the lb9 is 6 degrees advanced with the est disconnected.
https://www.thirdgen.org/forums/tpi/...es-91-z28.html
Old Feb 17, 2014 | 02:28 PM
ace322's Avatar
thanks the owner prior to me removed the VECI label so I had no clue at all. Now that I know that it's way off I'm definitely gonna resolve that issue today. Thanks
Old Feb 17, 2014 | 02:30 PM
Engine: Lb9
Transmission: M20
np
Old Feb 18, 2014 | 07:14 PM
ace322's Avatar
Ok here's an update on the the vehicle. I adjusted the timing to 6* BDTC with the EST disconnected. I reconnected the EST and tightened everything else down. The car started up fine but when I went for a drive it started surging on me a bit and using my Autoxray diagnostic tool it was showing that the vehicle was knocking when I would start getting on the throttle. When the car idles it feels like it's gonna die. Any ideas?
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
evilstuie
Jan 9, 2020 08:29 PM
Infested
May 22, 2018 11:56 PM
