flash rusting crank help.
Old Feb 22, 2014 | 11:06 PM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Right before this snow and cold crap hit us. I tore down a 350 to just the block and left everything sitting out. Well today I went out to my garage to get my tanks turned back on so I could start back on my motor and I noticed my crank journals are starting to get a light coat of rust on them. I can rub most of it off but what can I do now? I poured some fresh oil I had on all the bare metals for tonight but what else can i do?
Old Feb 22, 2014 | 11:28 PM
Zane M's Avatar
Car: 1991 GTA
Engine: LB9
Re: flash rusting crank help.
Keep it well oiled. You can also wrap it in plastic for some additional protection.
Old Feb 23, 2014 | 11:20 AM
Vader's Avatar
A water-displacing rust preventive coating can help if you must keep the metals bare and exposed. That is exactly what WD-40 was originally intended to be - A rust preventive coating. Temperature swings are going to cause condensation, so prepare for it.
The surfaces should be able to be cleaned with a mild abrasive and treated with a rust preventive. Avoid anything harder than flint paper or crucus cloth. Aluminum oxide sandpaper is not good for this purpose. Scotch-Brite can also be used. Any residue needs to be kept out of oil passages and cleaned away before assembly, just as you would usually do.
Old Feb 26, 2014 | 08:21 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Don't leave bare metal exposed, especially cast iron, in an unconditioned space. (no heat or A/C) It will flash rust and get worse as time goes by.
Spray the iron and steel parts with penetrating oil, WD-40 works great, and cover it with a plastic sheet. pistons are aluminum so not as big an issue.
Be sure to wash all the parts and blow dry with clean compressed air before re-assembly
cleaniless is Godliness..
Old Feb 26, 2014 | 08:30 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Ditto on WD-40 it is made to displace water, I always spray a little in my distributor cap when ever I have it off. Just my 2 cents.
Old Feb 26, 2014 | 09:23 AM
Maverick H1L's Avatar
Car: 2003 Hyundai Tiburon GT
Engine: 2.7L V6
Transmission: 6-speed
Axle/Gears: 4.41
Coat the crank journals in assembly lube after cleaning them with 0000 grade steel wool. You're going to use assembly lube anyways, so just do it now. I've never been a fan of the thin penetrating oils, especially since I coated my clean brake rotors with it and they rusted anyways. I had a 2.8 crank in my garage for 5 years before I scrapped it last year. I would assume it was coated in assembly lube since it was mounted in a block when I got it. You could easily tell the difference between the coated journals and the ones that weren't coated. And then wrap the crank in plastic wrap. I just hope you're storing it properly so it doesn't warp.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Stryker412
Sep 7, 2015 09:11 AM
Jetmeck
Sep 4, 2015 12:29 AM
Formula_88AE
Sep 3, 2015 01:47 PM
mrdevontay
Sep 2, 2015 08:04 PM
