No power to the starter!
Old Feb 26, 2014 | 11:59 PM
19GTA92's Avatar
Car: 1992 Pontiac Trans Am GTA
Transmission: 5 speed
I drove my car Sunday, and didn't drive it on Monday. I went to start my car on Tuesday morning to head to class, I put the key in the ignition and turned it to the start position but nothing happened. I tried that a few more times but still the same results. After a few minutes I tried again and it started. I drove the 20 or so miles to class, parked her, shut it off and went to class. Afterwards I went to leave and it didn't start, no sounds at all. The INFL REST. light would blink seven times and the security light would come on for a second. I tried everything I could think of to get it started but nothing worked. I then had a friend tow me around the parking lot today and started it that way. Once I got over to his house I took the starter off and took it to O'Rielly's to get it tested, and it passed. So I hooked it back up and tested to see if the purple wire that goes to the starter was getting power and it wasn't. Then I tested the NSS (neutral safety switch) to see if the switch was getting power and it wasn't. So I tried to bypass that with jumping a wire from the ignition switch to a power source and nothing happened. I replaced the ignition switch and I'm at a loss of what to do, any help is greatly appreciated! Thanks guys!
Old Feb 27, 2014 | 06:16 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No power to the starter!
Your car has VATS.
Do a search ,many posts on here about it
https://www.thirdgen.org/forums/tech...elay-vats.html
https://www.thirdgen.org/forums/post...06-post16.html
https://www.thirdgen.org/forums/tech...snt-crank.html
https://www.thirdgen.org/forums/tpi/...turn-over.html
Chuck84TA
Jul 15, 2016 09:05 PM
5spdcamaro
Aug 28, 2015 02:12 AM
L98GTA87
Aug 25, 2015 02:23 PM
sailtexas186548
Aug 24, 2015 10:11 PM
Accerrito22
Aug 23, 2015 07:22 PM
