cold kill my car? bc its not starting
Old Mar 3, 2014 | 05:04 PM
DARKmj16's Avatar
Car: 92 25th anv camaro rs
Engine: 305 tbi
Axle/Gears: 3.08s non posi
ok so here in MI its been freaking cold as hell and now my car (for the like 3rd time) just wont start. the 1st time I got a ride to work came back it started. some time goes by (like weeks time) the car just wont start, even when trying to jump it (ofc batt was full charged) but the starter motor wouldn't even engage, (plus when it was cranking it was slow and tired sounding) so new starter.
week later the alternator start throwing sparks and providing 10 volts... so new alternator.
another week later same thing again, car wont start, motor wont even engage. jump start works just fine, new batt.
but today... no start, jumping wont work. come back home when its warmed up a little, still no start, and jumping wont work.
its a 92 Camaro with the 305 tbi and 5spd. any help or ideas?
Old Mar 3, 2014 | 07:03 PM
Vader's Avatar
Re: cold kill my car? bc its not starting
Battery/chassis engine grounds intact? Battery cables in good condition? It sounds like it might be a connection problem at higher current.
Old Mar 3, 2014 | 09:00 PM
DARKmj16's Avatar
Engine: 305 tbi
ya all grounds intact and soild. (its my understanding if they weren't then nothing would come on, and everything comes on) and as far as I can tell the batt cables are good. and I agree something with the starter or between the start and batt is bad or happening. I forgot to mentain when trying to jump it you could hear the starter thump? but not crank, but only when the extra power was added. so maybe a bad starter?
Old Mar 4, 2014 | 08:57 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Bad batt cable. Just went through the same thing with my gmc plow truck. The starter end was corroded. Looked ok from the outside, but had lowered conductivity when I tested it. I actually replaced it with one from a 85 trans am tpi.
It had started ok when mildly cold, but when dropped below 10, just got the starter clunk and no crank. Everything looked fine as well, radio, fan, guages, everything worked, just not getting enough amps to the starter.
May not be the pos, could be the neg as well.
Old Mar 4, 2014 | 10:41 AM
RedLeader289's Avatar
Car: 1983 Z28
Engine: 385 Fastburn
Have you tried jumping it straight to the cables? (no battery connected). I've had this work before when a car wouldn't jump, took the battery out and jumped it straight to the cables and she fired right up.
Old Mar 4, 2014 | 11:22 AM
Dakota W.'s Avatar
Car: 1991 Christine Z28
Engine: RV Cam and Intake 350 SBC
Transmission: 5speed
Axle/Gears: 3.08 ls Posi
You'll still have use of your electronics, even with a bad ground. Check ALL your connections.
Old Mar 5, 2014 | 09:29 PM
DARKmj16's Avatar
Engine: 305 tbi
ok went ahead replaced both neg and pos cables, and when I cut the small wire that goes fromt he pos to wherever (alternator im assumeing) it had that green oxi rust... but she start right up. thanks guys.
Wade787b
Sep 29, 2015 01:15 PM
86Base
Aug 8, 2015 01:34 PM
mustangman65_79
Aug 8, 2015 12:07 PM
drathaar907
Aug 6, 2015 04:20 PM
