fuel tank help
Old Mar 4, 2014 | 02:44 PM
mk2389's Avatar
Car: 1984 z28
fuel tank help
Does anyone know if a 4th gen tank will fit on an '84 z28 with little to no modification? 4th gen tanks are all I can find at the junk yard
Old Mar 4, 2014 | 03:34 PM
Lakerman62's Avatar
Car: 1985 Z28 & 1997 Z28 SS SLP
Engine: Sbc 305 TPI & LT1
Transmission: 700r4 and A4
Axle/Gears: 9 bolt Posi 323 & Posi 323
Re: fuel tank help
should fit fine, the later 98-02 may have been plastic, but not sure...
Old Mar 4, 2014 | 03:57 PM
Chad85T/A's Avatar
Car: 85 T/A
Re: fuel tank help
Your fuel guage won't work. The 4th gen uses a different sending unit. There are threads on here that talk about this problem.
Old Mar 4, 2014 | 04:19 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
98+ has a different sending unit resistance. 90-270 ohm versus the 3rd gen 0-90 ohm reading. You can use the OEM 97 grand Prix sending unit to fix that on later models but their are also plumbing and emissions differences. Pretty sure the 93-97 tank fits other then a slightly longer filler neck. Keep reading. You'll find out all the stuff you need.
jbates346
Car Audio
25
Jun 10, 2020 08:27 PM
mustangman65_79
Apr 14, 2017 05:37 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
Glowsock
Aug 26, 2015 12:28 AM
AkDrifted
Aug 17, 2015 07:45 PM
