New engine, cranks, but weak spark.
Old Mar 5, 2014 | 09:32 PM
resop27's Avatar
Car: 89 325is, 91 z28
Engine: 2.5l 6, l98
Transmission: t56
Axle/Gears: 3:42
I just finished putting my new engine back into my camaro and I'm trying to get it running
Just a few quick details.
aluminum heads, 383, superram intake.
this has been a two year project, but today was finally the day I was ready to try and start it. The motor was first cranking real slow due to bad ground to the motor from the battery. replaced that ended up grounding from the battery to the frame. I now have a weak spark or no spark situation I'm getting fuel and have fuel pressure.
The grounding strap from the back of the heads to the firewall gets hot enought to smoke. So I'm concerned I'm not getting enough ground, could this cause the weak spark?
Old Mar 7, 2014 | 06:02 AM
Vader's Avatar
Re: New engine, cranks, but weak spark.
The ground strap getting hot means that it is carrying excess current, and is now a resistor. That can affect all the electrical systems, including the distributor and ignition control. I'd suspect the ground connection between the battery and body is not reliable, as well as possibly the ground from the engine to the battery.
Old Mar 7, 2014 | 07:33 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
What gauge is the ground strap? Personally I like to use more than one and at least 2 gauge
Old Mar 7, 2014 | 07:50 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
I'm negative about the positive, but I'm not so positive about the negative ! ! !
sounds to me like you have a short to ground.
What I like to do is attach the battery - cable to the motor mount. this makes the ground to the frame and the engine.
also make sure the battery + cable to the starter is not touching anything (headers, block, oil pan etc.)
I would not attach a ground strap to the cylinder heads for obvious reasons (spark plugs)
try using the intake manifold or the bell housing
better still remove the ground strap from the head and see if the problem goes away..
Caspar
Jun 19, 2016 11:19 PM
E Rod
Aug 28, 2015 05:17 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
92projectcamaro
Aug 6, 2015 01:20 PM
