Old Mar 6, 2014 | 08:55 AM
82_Camaro's Avatar
Car: 82 Z28
Transmission: Turbo 200C
Axle/Gears: 3.43
383
I'm possibly building a 383 and I'm going through what I would need. obviously crank and rods but I'm wondering if I need a 400 balancer or a 350 balancer. I currently have a fluidampr 620101 which is a 6.250. Any help would be great. and if you know of anything else I may need.
Chris
Old Mar 6, 2014 | 09:09 AM
HINKSON AUTO's Avatar
Re: 383
Chris
I would not put a fluid balancer on anything, If you seen what a fluid balancer when on a crank when its being balanced its not a good deal.
If your using a cast or forged crank go with a 6.0 rod and you can easily internally balance the crank.
Rods at least step up to the Scat Procomp rod with the 7/16 bolts. Using a stroker rod you will not have to use a reduced base circle cam either. Those rods should be right around 300.00
Pistons I have used a lot of the Mahle's with great results.
Whats your budget?
Old Mar 6, 2014 | 03:19 PM
1gary's Avatar
Re: 383
Howards track smart stroker with Scat stroker clearanced 5.7 rods(no pistons ring spacers rings needed or small base circle cam)and ICon pistons require Mallory metal for internal balance.180 grams in the front and 200 grams in the rear.
Old Mar 6, 2014 | 03:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383
Depends which stroker crank you use .
The cheaper ones are based on 400 cranks which require the specific 400 only flexplate and balancer.
The better quality stroker cranks are 350 based and use the normal "neutral" balance balancer and a reg SBC flexplate
Old Mar 6, 2014 | 05:02 PM
Re: 383
I use 6.000 rods all the time so far no need for ring spacers and no need for a 600.00 balance job either!! with 6.000 rod less side loading and less friction and lighter pistons as well. No reduced base circle cams either!!
Old Mar 6, 2014 | 05:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 383
That rod length argument has been going on for years and never resolved
http://www.iskycams.com/techtips.php#2005
Old Mar 6, 2014 | 09:26 PM
Re: 383
How many years ago was that article done???
Restricted 2 barrel engines the 6.250 rod works fine.
A good example is take a 5.565 rod and piston put in cylinder 1 and a 6.250 rod and piston in cylinder 6 and slowly turn the engine over and you can see the difference between the two.
Old Mar 6, 2014 | 10:40 PM
1gary's Avatar
Re: 383
The internal balance rotating assemblies are more durable.In my case I wanted to have the option of running a 700R and later have the possibility of running a T56.
I will not entertain the debate of long rod vs short rod.
LT1Formula
Oct 8, 2015 08:34 PM
JSDaddy189
Sep 26, 2015 03:50 PM
