flywheel/ clutch help
Old Mar 11, 2014 | 07:29 PM
Ratchet23's Avatar
Car: 1991 firebird
Engine: 5.7 v8
Transmission: manual
ok so i have a 91 firebird with an 86 camaro engine/trans its a 305 t5, well i blew that engine up so i bought an 84 k10 truck engine (350) and i just realized that my flywheel/clutch from the 305 wont fit. so what is my options as far as that goes. the flywheel wont fit over the snout on the back of the engine the old flywheel looks to be 2 and 3/8" while my 305 flywheel is 2' or so. i didnt have vernier calipers to measure it. i just want this car to be done as it is finally warming up here in rhode island lol.
Thanks in advance
Hammajob
Old Mar 13, 2014 | 04:12 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: flywheel/ clutch help
Are you sure about those years? 86 and 84 would both be 2 piece rear main engines, and everything should bolt up just fine. I would bet your 86 engine is an 87+ 1 piece RMS...
Old Mar 13, 2014 | 07:54 PM
Ratchet23's Avatar
Car: 1991 firebird
Engine: 5.7 v8
I bought the truck engine out of an 84 k10 and I did the block numbers and it said 80-85 truck, and I don't have the 305 block anymore but it may have been newer but I bought it carbd and if I'm not mistaken, 86 is the past year for carb stock?
Old Mar 13, 2014 | 09:41 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
I think the 305 was a 1 piece rms, and a previous owner put a carb on it. I think all you need is an earlier 2 piece rms flywheel and clutch. Do a search if that's all you need before you buy anything though, but I'm pretty sure that is the problem.
Old Mar 14, 2014 | 02:31 AM
Dens71TA's Avatar
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
1986 is the first year for the one piece main seal and last year for non-roller cam lifters and perimeter bolt heads. The engine block is an odd ball one year part. Last year for the carburetor is 1987.
If you are trying to attach a one-piece main seal flywheel to a two-piece main seal crank, thats your problem right there.
Old Mar 14, 2014 | 03:41 AM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Yeah I wasn't sure when the switch was for a 1 piece rms, I thought 87 was when they changed everything (seal, center bolt heads), but I think you're right 86 was when they changed just the rms .
Old Mar 19, 2014 | 11:13 AM
Ratchet23's Avatar
Car: 1991 firebird
Engine: 5.7 v8
So if I understand this, I can get an 84 camaro flywheel and it ahold work?
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
