the crankcase vacuum thread
Old Mar 13, 2014 | 06:38 PM
1991sleeper's Avatar
Car: 1991 firebird
Engine: TBI 305 (built)
Axle/Gears: 4.10
OK ... I know sometimes ppl go through alot of trouble to pull vacuum on the crankcase such as : header evacuators , vacuum pumps , pcv systems etc ... but I really don't have a lot of knowledge about this and would like to educate myself on the subject ..
But first I have a specific question ... I'm still running the factory pcv system and was thinking ... if I plug the passenger side valve cover and leave the pcv system in the drivers side would this not work quite well similar to a vacuum pump ? And help seal the rings a little better possibly ? Thanks !
Also Feel free to discuss the topic to full extent !
Old Mar 13, 2014 | 07:47 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: the crankcase vacuum thread
The PCV system does help with keeping the crankcase at a lower pressure however it's not the same as a proper evac system.
It's not just pressure or ring sealing. There's condensation (water) plus containments in the crankcase vapors. The PVC system sucks that junk and feeds it back into the cylinders to be burnt and set out the tailpipe. Water doesn't burn. Excessive oil vapor isn't good in the combustion chamber either.
With a header evac system, it's about as efficient as a PVC system except it's dumped directly into the exhaust. At the most, they'll only pull 2-3" of vaccum. Electric vaccum pumps work at low rpm and idle speeds but can't pull enough vaccum at WOT.
Belt driven pumps are the best for pulling a crankcase into a vaccum. If too efficient, a relief valve needs to be used to limit how much of a vaccum the pump will pull. Pulling lower than 12 inches can pull oil from the bearings and wrist pins.
If you have too much crankcase pressure then you have too much blowby past the rings. A proper fix is a rebuild. A good cylinder leakdown test should be in the 2-5% range.
Old Mar 13, 2014 | 09:13 PM
The reason people use mechanical pumps of whatever sort on race cars, is because, at WOT, THERE IS NO VACUUM. PCV does nothing whatsoever.
For a street car,,, ... ,,, .. whole different matter.
That's one of those things that just because "all the fast cars do it", doesn't always make sense for the rest of us.
If you run your 305 TBI car on the street, the factory PCV setup works JUST FINE as it is. Use it to your advantage. There's nothing to be gained by blocking the system's make-up air intake.
Old Mar 14, 2014 | 08:33 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Everything you wanted to know about the PCV system:
http://en.wikipedia.org/wiki/Crankcase_ventilation_system
Old Mar 14, 2014 | 08:40 AM
FRMULA88's Avatar
Car: 1988 Formula
Everything you wanted to learn about crankcase evac systems.
An overview of Passive systems & Vacuum pumps systems
http://www.enginelabs.com/engine-tec...up-horsepower/
Welcome to Hot Rodding ! Hope you enjoy reading !
Old Mar 14, 2014 | 08:41 AM
FRMULA88's Avatar
Car: 1988 Formula
Vacuum Pump Advantages
Pulling vacuum with a dedicated pump has been the preferred method for well over two decades now and the technology has steadily advanced with important performance benefits that include:
•Improved ring seal by relieving crankcase pressure below the rings
•Reduced friction by allowing lighter tension rings
•Reduced windage around the rotating assembly
•Improved oil scavenging
•Reduced parasitic pumping losses
• Minimized cavitation (in wet sump applications)
•Reduced lubricant contamination
•Improved bay to bay breathing in Y-block configurations
•Improved power via reduced mixture contamination
•Reduced gas port contamination
Old Mar 14, 2014 | 11:42 AM
Car: 1991 firebird
Axle/Gears: 4.10
Cool man ! Good read
gta892000
Aug 11, 2019 11:16 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Linson
Sep 21, 2015 01:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
snakeshooter
Sep 7, 2015 11:13 AM
