Need help with car problem pls 91 Camaro
Old Mar 28, 2014 | 07:02 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
1991 Camaro 305 TPI. After 10 min of running rpms jump to 2000 in park runs rough when step on gas put in gear car dies then wont start only when putting pedal to floor starts up and dies. car sits for a while the start back up and same thing. the only code it gives is 15 faulty coolant sensor or wiring with sensor which to me should not cause this problem. any help would be great thanks
Old Mar 28, 2014 | 07:53 PM
MMroc86's Avatar
Car: 1986 IROC-Z28 & 1987 GTA
Engine: 305 TPI & 350 TPI
Re: Need help with car problem pls 91 Camaro
Sounds like it could be a problem with your mass air flow sensor, unplug it & see if it runs better.
My 87 T.A was doing that, but when I unplugged the MAF it would stay on & was driveable. Not sure if the 91 cars still have an MAF tho....
Old Mar 28, 2014 | 08:06 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
Hi thanks for the reply no it doesn't have one
Old Mar 28, 2014 | 08:29 PM
MMroc86's Avatar
Gonna take some serious troubleshooting to find/fix this. Start with the basics.
Check your fuel pressure, I believe you should be at around 37-43
Change the fuel filter.
Check fuses, sometimes you get lucky.
Check all major grounds, do a search for the location, I'm not sure where they are all at.
Make sure all connectors are plugged in correctly.
Your car must be speed density/map. If it does the samething as the maf, then it might be causing your problem.
Search speed density or map problems & see if you find ppl with similar issues related to that sensor.
Old Mar 28, 2014 | 08:36 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
K thanks ill look at those. first thing I did was fuel filter.
Old Apr 3, 2014 | 10:16 PM
Timbo89GTA's Avatar
Engine: 383 TPI
Axle/Gears: 3:27
So just an update for those who looked. It ended up just being the temp sensor in front of the intake. Replaced it and car ran and started fine. did not think it would of caused that problem. Cheers
rocn7roc
Sep 21, 2021 02:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tony Ferrarri
Aug 11, 2015 07:59 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Fronzizzle
Aug 9, 2015 01:15 PM
