Enigne knock
Car: 1991 Firebird convertible
Engine: LQ4 ls 6.0
Axle/Gears: 342 Limited slip
Enigne knock
I have a SBC 377 and over reved it today and now I have a knock but only at idle and it is a solid knock not a tapping my oil presser gauge reads 20psi at idle it has a scat forged crank and the crank was ordered with the right main journal so I didn't use spacers any ideas what it could be
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Enigne knock
Spun rod bearing or bad wrist pin is the most common source of a knock.
Main bearings don't knock. Spun cam bearings don't knock.
Getting a knock after over reving the engine could still be a failed rod bearing (stretched rod bolts). You could have floated the valves and at least one is now bent.
Doesn't really matter. If your engine has a knock, it will need to be stripped down for repair. The longer you put it off, the worse the damage can become.
Pull all the spark plugs to see if one is damaged.
Engine: LQ4 ls 6.0
Re: Enigne knock
Yeah wrist pin is what I was thinking would it still have good oil presser if it was a spun bearing the engine only has 25000 miles on it
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
