engine codes and idle help!!!!
Old Apr 1, 2014 | 03:12 PM
ace13733's Avatar
Car: 86 chevy camaro iroc, 82 chevy k20
Engine: 305 tpi
I just bought a 86 iroc 305 auto trans everything is stock to my knowledge my problem is that number one the car idles high tach is off so I'm not sure what it's idling at but I can hear it the car also is throwing trouble codes #'s 41, 25, 53, 52, 44 do you guys think the computer is junk or what? Car runs fine never stalls or anything sometimes it starts hard (like cranks over quite a bit before it fires then kinda weak when it starts but then idles high again) any help would be great!!!
Old Apr 1, 2014 | 05:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
An '86 IROC could have the carbureted LG4 (8th character of the VIN = H) or TPI LB9 (8th character of the VIN = F). Which do you have?
It's actually pretty rare for the computer to have a problem, and when it does, it's even more rare for it to tell you what's wrong with it. When codes are set, it's typically a result of input from a sensor.
I'd suggest clearing the codes (https://www.thirdgen.org/service-eng...ht-error-codes) and driving it some more, see if any of the codes reset.
Code 41 will be set when the timing is adjusted. Takes awhile for it to clear on its own afterwards unless you reset it per the link above.
Old Apr 1, 2014 | 06:56 PM
ace13733's Avatar
Engine: 305 tpi
Re: engine codes and idle help!!!!
I have vin letter f. It's the 305 tpi, I cleared the codes so I'll check them again tomorrow when I get to work. It never had a check engine light on either I just wanted to see what the rpms were actually at when idling but I happen to stumble on the dtc codes instead.
Old Apr 4, 2014 | 05:06 PM
ace13733's Avatar
Engine: 305 tpi
So after clearing the codes driving a little I checked the codes again and got this list, 25, 41, 44,51,52,53,54,55. What could be the problem it seems to run just fine???
Old Apr 4, 2014 | 05:35 PM
ace13733's Avatar
Engine: 305 tpi
Spyder_TheGamer
Dec 25, 2015 05:07 PM
backtothe80s
Sep 5, 2015 12:39 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
