v6 camshaft help
Old Apr 2, 2014 | 03:40 PM
up_dn_man's Avatar
v6 camshaft help
I have a 89 Camaro with 2.8l v6. I want to put a new cam in and do some head work. I was thinking a melling mtc-5 cam. I was going to put new valve springs, retainers, and lock. What else should I replace. Can I use the stock injectors with this cam. Also do I have to pull radiator to remove and put in new cam. I already have headers and true duel exhaust.
Old Apr 3, 2014 | 10:24 AM
drdave88's Avatar
Car: 1998 Camaro Z28
Engine: 6.0L
Re: v6 camshaft help
I had the MTC-5 cam in my 3.4 with springs, etc, was a nice addition. Head work would be good, but an even better improvement would be porting the intake manifold. I have a thread on here for a few years back about the gains i got on a flow bench from porting the 2.8 intake. That really woke it up above 4500rpm. Try a search in the V6 forum, this is discussed a lot in there.
Old Apr 3, 2014 | 01:49 PM
up_dn_man's Avatar
Yes I already have a ported intake and both plenums. Do I have to pull the radiator to get the camshaft in?
Old Apr 4, 2014 | 07:25 AM
drdave88's Avatar
Engine: 6.0L
If I remember correctly, I just had to unbolt the radiator support at the top and pull it back a bit, but not actually remove it.
Old Apr 4, 2014 | 01:12 PM
up_dn_man's Avatar
Do i have to get new injectors? And are the stock one 15 or 17 lb. Do you know if they make an adjustable fuel pressure regulator?
Old Apr 4, 2014 | 01:36 PM
drdave88's Avatar
Engine: 6.0L
You can stick with stock ones, which i believe are 13. Its been discussed in the V6 forum before, some say 13, some say 15. I dont remember what the outcome of that whole discussion was. I think you can get an AFPR for the TPI engines and use that. I had one (may still have it) but never bolted it on.
Old Apr 4, 2014 | 06:49 PM
ex-x-fire's Avatar
Don't they have 1.6 roller rockers too?
Old Apr 4, 2014 | 08:06 PM
up_dn_man's Avatar
Stock they have 1.5. I know that comp cams has aluminum rocker that are 1.6. I was going to keep the 1.5
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
