car wont go faster than 10 mph
Old Apr 1, 2014 | 05:23 PM
casson4's Avatar
Car: 1985 camaro berlinetta
Engine: carb'd lg4 305
Axle/Gears: 3.08's sonn to be 3.73's
car wont go faster than 10 mph. i can rev it in park but it sounds sluggish and it hesitates alittle but when i put it in drive no matter how hard i press on the gas the rpm's wont pass roughly 1000. here's the story i was driving home from my friends house at night and i pressed on the gas when the light turned green and let off the gas, as soon as i let off it felt like the car died which it did five seconds later so i pulled over and came to a stop and went to put it in park and it made a zzzzzz sound when i tried at first. finally i tried to drive it and as soon as i turned it on a very strong burning smell started then when i tried to drive the kid following me said there was black smoke comin out the tailpipe.
any input or help would be great thanks
Old Apr 1, 2014 | 05:29 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Re: car wont go faster than 10 mph
That sounds like you broke something.
Does it sound like a dinner bell ringing when you run it? Or do you hear any clicking or hammering sound from the motor at idle?
Old Apr 1, 2014 | 05:35 PM
casson4's Avatar
that's the weird thing it doesn't sound any different when running, besides the slight hesitation when i rev it
Old Apr 1, 2014 | 05:38 PM
casson4's Avatar
another thing i wanna add is that my torque converter has been unplugged for roughly 1xxx miles so could that also be part of the problem
Old Apr 1, 2014 | 06:25 PM
CEP89's Avatar
Car: 89' IROCZ
Engine: 5.7 L98
Check your trans fluid. Is it red or dark? Does it smell burnt? Any specks of bright metal?
Old Apr 1, 2014 | 06:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
plugged catalytic converter can cause that(if one is still in place)
Old Apr 1, 2014 | 07:11 PM
casson4's Avatar
nope i have straight pipe
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
B_Dubya
Aug 26, 2015 05:09 PM
jpearcy1
Wheels and Tires
Aug 9, 2015 10:20 AM
