Quick firing order question.
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Thanks for anyone who is reading or read this. I've used the search, can't find anything super specific.
OK so I forgot to mark distributer. So I read you put your finger the 1# spark plug hole and yadda yadda and turn the engine. Well. I have to use two hands to turn it over from the harmonic balancer? So I can't keep my finger over it. Is there any other way? Or easier way to turn. I gotta leave to work and the keys to the other car are gone
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Quick firing order question.
Check the muffler bearings, they are probably seized and making the engine hard to turnover.
oh and by the way
APRIL FOOLS !
oh and by the way
APRIL FOOLS !
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
:3 I'd laugh if I wasn't in such a rush. I got no one to help by holding their finger over it. BTW my op is for serious.
Car: 1983 Z28
Engine: 385 Fastburn
Are you trying to figure out when the cylinder is at TDC or are you trying to figure out the firing order? The firing order should be stamped somewhere on the block or intake.
If you need both hands then take a shop rag and use your finger to push into the spark plug hole. Turn the engine over and compression will pop the rag out, pretty close to TDC for that cylinder.
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Trying to find the order in which the plug wires go from the engine to the distributer.
Car: 1988 Formula
you can do it with one hand for sure and a 12" long wrench
otherwise pull the valve covers and watch #2 & #1 rocker arms.
18436572.....
If #1 is at TDC when you re-install the dist. the rotor should point towards #1. you can get this close enough to start the car then dial it in with the timing light. the firing order is 18436572... starting with #1 install the wires clockwise on the distributor.
Car: 1988 Formula
Correction... the firing order for your motor should be committed to your memory... SBC & BBC s and pretty much all "old school" GM V8s are 1-8-4-3-6-5-7-2
unless you are dealing with LS engine & they just swapped 4/7 3/2
1-8-7-2-6-5-4-3 which is similar to Ford firing order...
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
Ok it popped out. Now the distributer rotor is pointing just before the **** on the cap. Is that one #1 or the one before it.
Car: 1988 Formula
if #1 piston is at TDC then the rotor should be pointing to the #1 spark plug...
this is just a rule thumb
The rotor turn clockwise... so the terminal just ahead of where the rotor is pointing to the #1 plug is your #1 terminal on the dist cap.. then clockwise after # 1 is,... 8 then
4 then 3 theeeeen 5 theeeeeeeen 6 followed by 7 and finally... 2
1 8 4 3 5 6 7 2
1 8 4 3 5 6 7 2
Car: 1991 RS
Engine: Stock 305
Transmission: Stock
Axle/Gears: Stock
1 8 4 3 5 6 7 2
1 8 4 3 5 6 7 2
