timing help
Old Apr 7, 2014 | 06:01 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
timing help
what causes timing to keep advancing? i cant seem to get my timing to stop advancing at all. at 4500rpm its about 50* and climbing. stock hei dist with msd ignition. any ideas?
Old Apr 7, 2014 | 06:19 AM
Re: timing help
What is making you think it's advancing?
How does it run when it's "advanced", compared to when it's not where it belongs?
Old Apr 7, 2014 | 07:18 AM
Engine: 355
Re: timing help
when i time it at 3000rpm im at 36 degrees. i then rev it up to see if it quits but as soon as i hit 4500 it starts to climb from my original setting all way up to 50 degrees. i dont have vac advance hooked up. mech only
Old Apr 7, 2014 | 08:08 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: timing help
What springs do you have in it?
Did it come with a manual?
Many HEI distributors continue to advance well past 3K with the stock springs. Just because you set it at some random point at 3k RPM does not mean it magically knows when to stop.
You need the timing adjustment kit for a HEI distributor.
Second thought is your timing light compatible with the MSD ignition? Many dial lights get screwed up be the multi spark. Your best best is timing tape and a normal light.
Old Apr 7, 2014 | 08:17 AM
Engine: 355
Re: timing help
IT had the stock springs which were really stiff, i changed them out to the gold springs that i purchased from summit. i have a normal light plus timing tape. how would the spring change opening rate? im a little "confused" by it
Old Apr 7, 2014 | 08:59 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: timing help
light weight springs makes the timing all in sooner.whereas stiffer ones make it come in at a higher RPM
Old Apr 7, 2014 | 09:31 AM
Engine: 355
Re: timing help
gotcha
Azrael91966669
25
Jun 20, 2017 04:04 AM
bamaboy0323
Sep 3, 2015 06:07 AM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
Thirim
Aug 9, 2015 06:19 PM
