5.7 tpi, fuel, spark, no start.
Old Apr 14, 2014 | 05:51 AM
lsd88ta's Avatar
Car: 1988 Firebird Trans Am
Axle/Gears: 3.27:1 LSD 9 Bolt Disc Rear
my 1988 trans am 5.7 tpi auto will not start
about a week ago it would barely start and using 1/4 throttle helped it start and then it would idle really rough on about 5 cylinders and slowly clean up and run ok.
now it just wont start, it winds over and over and will not fire up. at first I could hear it fire one or two cylidners but it got worse trying to crank it, and now no hint, it's like I have no spark, yet I have spark at the spark plugs?
I've replaced ECM, distributor module, spark control module, new coil, has new cap and rotor button, over the last 2 years it's had new starter motor, new iac, tps coolant temp sensor, oil pressure sensor, oxygen sensor, new plugs and leads.
when winding engine over it has spark at the spark plug. and fuel pump primes and his 41psi rail pressure, I even tried spraying extra fuel into the intake manifold to be sure but still no start. it's so strange to have spark and fuel and no start... when I wind it over I start to smell a bit of a fuel smell but no start. normally I've been able to figure these kind of things out, but I'm lost. there are no check engine codes as the engine wont run to even throw a code. I've also checked fuses. my only other thought is, pickup coil? or some wire has come off something and preventing it from running? any help is greatly appreciated.
Old Apr 14, 2014 | 09:43 AM
TX-SleeperC5's Avatar
Car: 1987 Trans Am GTA
Engine: 5.0 TPI
Re: 5.7 tpi, fuel, spark, no start.
I'm having the same issues with a NEW motor !!
Old Apr 14, 2014 | 03:17 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
What does the ECM think engine temp is?
Old Apr 14, 2014 | 05:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Seeing a spark on a plug out of the engine and it being strong enough to the fuel mixture in the cyl are two different things.
The fact it wouldn't fire with fuel squirted is a dead giveaway your spark is weak or missing
Run these tests
http://easyautodiagnostics.com/gm_ic...n_module_1.php
Past codes seen are stored in the ECM ; engine dosen't have to run to see them
Old Apr 15, 2014 | 04:00 AM
lsd88ta's Avatar
thanks for that vetteoz, I'll read through that and see how things go.
Old Apr 15, 2014 | 09:00 AM
91 rally sport's Avatar
Car: 85 iroc z, 03 ram 1500
Engine: 305 tpi, 287
Transmission: WC T5, NV3500
Axle/Gears: 3.42, 3.55s
Did u do a compression test?
Old Apr 16, 2014 | 02:47 AM
lsd88ta's Avatar
FIXED! previously I had cleaned the spark plugs and no change. I checked them for spark outside of the engine and they sparked. it turned out spark was dead under compression. a new set of spark plugs and it fired up and runs great again. I guess the lesson there is, don't think the plugs are working because you cleaned them and they spark outside of the car. try a new set of plugs. I can't believe it lol. but there we go. very happy. thanks guys.
Old Apr 16, 2014 | 06:47 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
I guess the lesson there is, don't think the plugs are working they spark outside of the car. .
Similar situation occurs if your plug wires are old.
Spark will take the path of least resistance so even if the plug is seen to spark out of the engine as soon as it is subjected to cyl pressure,
the spark will escape from a deteriorated plug wire or cracked dist cap
Old Jul 9, 2014 | 04:54 PM
gta_knight's Avatar
Car: 1987 GTA
Engine: 350 TPI w/ extras !
Im having the same problem with my car now, ive just done a 5.0 to 5.7 swap, and my 5.0 was doing the same thing before i pulled it out, just cranking over and over
the 5.7 fired up first time but felt like it was running on like 3 cylinders, i was getting spark, good fuel pressure but it was just missing and ran terrible. And now it wont start at all, it just cranks continuously.
Im using the same NGK plugs from the 5.0 engine in the 5.7 so ive got a new set of plugs on the way, if it turns out to just be the plus i will be so happy.
So if just one of your plugs crapped out would it cause the car to just crank over all the time without even trying to fire up ?
Old Jul 10, 2014 | 06:59 AM
If its not the plugs. Did you see if the injectors are firing?
Old Jul 10, 2014 | 08:52 AM
gta_knight's Avatar
Car: 1987 GTA
They are pulsing fine, and they are also brand new injectors from southbay
Old Jul 10, 2014 | 12:23 PM
Hawkeye1980's Avatar
Car: 1989 Firebird Formula 350
Engine: 5.7
Axle/Gears: Stock
all this sounds like timing???
1992 Trans Am
May 10, 2023 07:19 PM
theshackle
Mar 5, 2017 06:37 PM
jharrison5
Aug 19, 2015 05:53 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Sanjay
Aug 12, 2015 03:41 PM
