need push rod help
Old Apr 21, 2014 | 08:48 PM
mike22115's Avatar
Car: 1990 firebird formula
Engine: 355 HSR comp xfi 268 vortec heads
Axle/Gears: 3.27 BW 9bolt
need push rod help
im building a 350 and cant decice on push rod length. do i use stock or will it need to be changed. heres my specs
350-bored .040
vortec heads .600 springs screw in studs with guide plates
cam is comp xfi 268, .570/.565
if anyone can help out that would be awesome
Old Apr 21, 2014 | 09:38 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: need push rod help
There are too many variables that you don't have listed and even then it would be a guess that I wouldn't want to risk. Just buy a pushrod length checking tool and then you can trust that you did the job right and no worries about bent pushrods, broken rockers, etc.
Old Apr 21, 2014 | 10:43 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
If you're changing anything that adjusts the lift of the pushrods or valves, you need to check for proper length. You might be able to reuse them, but you won't know until you get the stuff installed and can check it. Read up: http://www.carcraft.com/techarticles...h/viewall.html
While that is by no means all inclusive, it will help. There are other threads on this site where some experts and pros discuss the right and wrong ways to do it. If all else fails, ask a question.
RS Reaper
Oct 17, 2018 07:52 PM
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
