Belt Woes
Old Apr 24, 2014 | 02:04 AM
Annihilate's Avatar
Car: 1988 IROC-Z/G92
Engine: 5.0
Axle/Gears: BW 3.45 Eaton Truetrac
Belt Woes
After recently taking the belt off my Alternator, and then putting it back on, it squeals quite loudly when revving quickly. This never happened before. What could be the issue?
Old Apr 24, 2014 | 06:21 AM
ex-x-fire's Avatar
Re: Belt Woes
Any tight pulleys, weak tensioner, misalignments, or sometimes putting the used belt on backwards can cause noise.
Old Apr 24, 2014 | 07:37 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
Re: Belt Woes
Assuming this is a serp belt, probably the tensioner. By manipulating it, it may have changed the stress on the spring or pulley, or introduced some dirt into it. It's either a warning sign of the tensioner starting to go or it will go away.
MrPackstin
Oct 25, 2017 08:09 PM
sparks454
Interior Parts Wanted
Oct 18, 2015 03:18 PM
SRKLEGIN
Oct 12, 2015 07:28 AM
SRKLEGIN
Sep 30, 2015 07:19 PM
kitt23
Sep 26, 2015 07:48 PM
