Installing T fitting on Fuel lines for test valve. how should i release fuel pressure
Old Apr 23, 2014 | 07:39 PM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Hey all im installing this kit onto my TBI motor so i can check fuel pressure seen here...
https://www.thirdgen.org/forums/tbi/...-b-i-fuel.html
my pics are right there on last post.
Any way i was wondering how should i release fuel pressure? the only reason why i ask is because years ago i was having start up problems with the original motor and i opened my feed line shown in that thread on post #14 and when i opened it up, it flooded out quick and almost filled a 32 oz cup. (obviously my problem wasnt fuel at the time lol ended up being ICM) any who any time i work on my throttle body and have to open up the feed&return line behind the FPR it dripples out slowly and barely any fuel. idk why i think its going to come out quick. Any who any ways to release fuel pressure with out pulling the fuse that is located above the rear end (thats the only one i know of)
thanks all!!
Old Apr 23, 2014 | 08:15 PM
DynoDave43's Avatar
Axle/Gears: 10 Bolt 2.73 Open
Re: Installing T fitting on Fuel lines for test valve. how should i release fuel pres
Interesting. I didn't know the tbi cars had such an inaccessible remote fuse.
Old Apr 23, 2014 | 08:44 PM
chevyredneck8's Avatar
Car: 88 Iroc Z
Engine: L98 350
Transmission: 700 R4
R u just trying to release fuel pressure before cutting in a fitting?
If so disconnect the battery then break a fuel line fitting lose suggestion if you haven't change ur fuel filter that would be a good spot to drain it down and swap the filter while ur at it.
Old Apr 23, 2014 | 10:46 PM
Yeah it sucks
Yeah im just installing a T fitting. Basically just an adapter with a "Schrader valve" on it Where the fuel lines come into the engine and go to rubber.
Question; How does disconnecting the battery release pressure on the fuel lines?
just did fuel filter about 200miles ago
Old Apr 23, 2014 | 11:38 PM
Car: 88 Iroc Z
Engine: L98 350
The battery is more of a safety precaution last thing u want is a spark or have the fuel pump turn on while a line is lose.
I normally relieve pressure by just slowly cracking open a fitting like the fuel filter and let it drain if u worried about pressure. Disconnect the fuel pump relay turn the engine over a few time and the injector should cycle and dump most of the pressure
Old Apr 24, 2014 | 10:09 AM
khulsebus's Avatar
Car: '89 Camaro
Transmission: 4L65/70E
Axle/Gears: 9 Inch, 3.70 gears
You should have a fuel pump relay under the hood. Honestly I can't remember which one, but on my old '91 RS I believe that I only had two relays under the hood on the drivers side. One for the fan and one for the fuel pump. Disconnect that and crank the car for about 5-10 seconds to purge out the pressure before you crack a line.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
beachrodder
Aug 25, 2015 08:05 AM
AkDrifted
Aug 17, 2015 07:45 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
