polyurethane motor mounts
Old Apr 25, 2014 | 09:58 PM
Slow87's Avatar
Car: 87 Camaro Lt
Axle/Gears: 4th gen 3:42, posi, disc
Just switched to the poly motor mounts and have two questions.
1. Are the inserts facing the right way? Seemed like the could fit inside the clamshell either way.
2. Are these the right inserts? The part of the mount that bolts to the actual block wont slide over enough to line up the holes. It seems as though I either have to shave part of the gold tab that sticks out of the insert, or I have to bend the tabs on the mount to make enough clearance.
Old Apr 26, 2014 | 04:01 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: polyuerothane motor mounts
Who are they made buy ?
If its Energy Suspension I might be able to see mine. I will look at them as soon as I can.
Old Apr 26, 2014 | 05:17 AM
Slow87's Avatar
Car: 87 Camaro Lt
Yeah they're ES mounts. Any help is appreciated.
E Rod
Aug 28, 2015 05:17 AM
Wesly_66
Aug 26, 2015 09:55 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
