It will turn over but won't start.
Old Apr 29, 2014 | 01:56 AM
OConnorRacing's Avatar
Car: Harley
Transmission: tb 350
Axle/Gears: no idea
It will turn over but won't start. 1988 Camaro. 1986 350 TPI 350 tpi L98 engine was running now will not start what could be wrong?
Old Apr 29, 2014 | 07:19 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: It will turn over but won't start.
Originally Posted by OConnorRacing
will not start
Big ask on that little info.
Have you done basic tests like seeing if you have spark at the plugs?
Will it fire up if you spray fuel in ?
Old Apr 29, 2014 | 01:22 PM
Car: Harley
Axle/Gears: no idea
I am looking to buy the car the current owner did something to the car to make it not run, he said it was running he did some burnouts with the car, then the car would not turn over>
Old Apr 29, 2014 | 04:57 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Not turn over ( crank ) or not start ?
Two completely different problems
Buy it only if he can get it to fire up and run
Old Apr 29, 2014 | 05:44 PM
Car: Harley
Axle/Gears: no idea
cranks but will not start, the guy is not exactly a hands on mechanic, I think he did something that screwed it up?
Old Apr 29, 2014 | 08:48 PM
Car: Harley
Axle/Gears: no idea
Finally got to the true,this is what he just said:
The red wire to the alternator was cut. I hooked it back up to see if the battery would start charging. Drove it around the block and parked. Went to start it again and it would only crank. It wouldn't start. So I got pissed and put it for sale.
Old Apr 29, 2014 | 09:11 PM
killer777's Avatar
Car: 1989 Firebird Trans Am
Engine: 355
Alright bud.
You need very specific things for an engine to run correctly.
Spark (at the right time and enough heat)
Compression
Fuel air mixture (Correct)
but this is basic. There is A LOT of other things that could possibly be wrong and no one on here will be able to help if you cant suck some information out of the guy or test it yourself.
Some simple things that this guy could easily check for are
Spark- take the plug out and turn the engine over
compression-place finger over hole of plug and check NOT ACCURATE AT ALL
fuel- look at the plug after turning it over for remnants of fuel
trouble codes- connect the right pins on the OB1 plug in or read it with a code reader because if it is a sensor on the engine that's inhibiting the starting or running of the engine, it'll kick codes back
make sure all important things are actually connected
Good luck. Give these guys a little more info and they should be able to help you in a few hours time, and easily diagnose the problem.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Glowsock
Aug 31, 2015 09:01 PM
WIzmo
Aug 30, 2015 02:30 PM
destroyerwes
Aug 26, 2015 08:17 PM
djmarch
Aug 19, 2015 12:07 PM
