fuel line o-rings: need replacements
Old Apr 30, 2014 | 11:43 AM
Ghettobird52's Avatar
Car: 88 Firebird Formula
Engine: LO5 5.7 TBI/Ebl Flash
Axle/Gears: 2.73 stock rear end
Anyone know what size o ring is on the feed line of fuel lines?
Any one know if they sell replacements at AutoZone/ Oreillys? Will regular o rings work or does fuel need specific type.
Thanks all!
Old Apr 30, 2014 | 05:54 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: fuel line o-rings: need replacements
They need to be Viton seals. Any auto parts store can get Standard Motor Products part # SK18.
Old Apr 30, 2014 | 06:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Originally Posted by Ghettobird52
Anyone know what size o ring is on the feed line of fuel lines? !
Save this for future reference
http://webpages.charter.net/khasting...uelsystem.html
Old Apr 30, 2014 | 07:09 PM
Are these Viton? I picked up a little Dorman pack assortment of o rings for $8.99 from autozone and found one that should work
Old May 1, 2014 | 08:36 AM
sweetmelissa's Avatar
Car: 1989 Iroc-Z
Engine: TPI 350
Axle/Gears: 3:27's
Auto Zone sells 2 kinds,,, one is for multiple uses and the other is for fuel only.. Read the back of the package to make sure you get the right one.. It will say "fuel only" on it !!!!
Old Jun 28, 2015 | 03:03 PM
ramicio's Avatar
Car: '87 Flame Red/Carmine Red GTA
Originally Posted by vetteoz
Wow! Thanks for posting that! I've been tearing my hair out trying to find these sizes so I can order these o-rings in bulk. Does anyone know of the size required for the large cold-start fitting that goes into the rail?
Old Jun 28, 2015 | 03:41 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
According to the posted link, it's a -106. O-ring sizes are cataloged by the dash number. All -106 o-rings are the same size regardless of the material they're made of.
For future reference: http://www.marcorubber.com/sizingchart.htm
I buy o-rings here: http://www.mcmaster.com/#
O-ring selector: http://www.mcmaster.com/#o-rings/=xtoll9
I know, you don't like to buy 100 pieces when you only need one. Believe me, having o-rings on the shelf is a good thing - they're cheap enough.
Old Jun 28, 2015 | 04:57 PM
ramicio's Avatar
My post said specifically that I like that I found the sizes so I can buy them in bulk... They are required to be replaced any time you loosen the fitting. They apparently seal by being crushed to destruction.
That's not the right o-ring. That's for the tube that goes into the fitting. The fitting that goes into the rail is much, much larger, and not listed there. I don't have one to even measure.
Old Jun 28, 2015 | 08:44 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
FWIW, some folks on other forums claim that the fitting o-ring is/was only available in the kit that replaces the entire fitting. There are also claims that the GM parts catalogs are incorrect and vague.
Determining what the o-ring groove dimensions are in the fitting might point you in the right direction.
Old Jun 28, 2015 | 09:17 PM
ramicio's Avatar
I'd much rather just get a whole 89+ setup from the intake manifold up at this point. The last few o-rings I've put in that spot have destroyed, because they're incorrect. If I take out the fitting now to measure it, I'd be SOL.
Old Jul 2, 2015 | 05:38 PM
ramicio's Avatar
I just wound up ordering a pack of -113 o-rings. O-rings I tried before were a little larger diameter, but only 1/16" thick material, and they tore. A -113 is 9/16" ID and 3/32" thick.
Old Nov 19, 2016 | 12:59 AM
I just want to update this thread. I ended up using that dorman o-ring and have had no problems since then.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
wayshegoes
Aug 17, 2015 12:00 PM
