Vacuum hose location?
Car: 88' Firebird Trans Am
Engine: 305ci
Transmission: Manual
So my selector on the control panel for ac/heat only blows out of the defroster. I know this is a vacuum leak somewhere so I searched for loose hoses and I eventually found a hose that was cut off and barely visible in a wire harness. It's in the same harness that goes through the firewall. So more than likely this is my problem. The question is if I were to connect a hose to it where would it go to? I can't find any places to plug it into. Does it possibly plug into something with the air pump? If so, mine has been removed. So any suggestions?
Car: 1987 IROC Z w/T-Tops
Transmission: Automatic
Axle/Gears: G92
Re: Vacuum hose location?
A search revealed this thread: https://www.thirdgen.org/forums/tech...iagrams-i.html
86CamaroDan
Sep 29, 2015 10:08 PM
