Hp estimation
Old May 8, 2014 | 10:40 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Axle/Gears: 3.42 Detroit locker
Hp estimation
Hey guys, I've just put together a new motor. Looking for hp estimates.
It's a 350 30 over..
Details are:
Heads: 882 ported and polished (I think 1.94 and 1.50)
Intake: edelbrock performer
Cam: Camshaft, Hydraulic Flat Tappet, Advertised Duration 280/280, Lift .480/.480
Carb: 600cfm edelbrock
Pistons: not much info other that being dished with 4 valve reliefs
Headers : 1 5/8 shorties
Old May 9, 2014 | 01:58 AM
visitor's Avatar
Car: genesis, equus, f250, camaro, other
Engine: 5.7
Transmission: t5
Re: Hp estimation
12.
Old May 9, 2014 | 07:56 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Hp estimation
Hey Mr. Visitor , What's up with the nasty dis of TGO in your sig ? You got NO right lumping the entire site together as folks who take the lazy way out of all repairs and I for one think your a jerk for doing so !
PS , I have NOT cut any holes into my car either , , , Difference is , I don't go acting all superior on the internet about it , like Mr. better than everyone else "visitor" does .
I'd say we got one "visitor" whose worn out his welcome ........
Old May 9, 2014 | 08:10 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: Hp estimation
don't feed the trolls LOL !
Old May 9, 2014 | 08:20 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: Hp estimation
Hi FRMULA88 ,
You sir are most correct in that , to respond to a troll gives the troll just what he's looking for , a rise outta someone . Normally I do ignore such comments as visitor made but to insult the entire site by calling everyone here hacks just couldn't go unmentioned . TGO is by far the best and most informative site for our cars and I really resent someone throwing mud at something like TGO that has helped myself and SO many others .
Old May 9, 2014 | 08:34 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Re: Hp estimation
Seems like a lot for cam for 882 heads were they milled down to increase compression?
300ish
Old May 9, 2014 | 10:14 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: Hp estimation
Thats what I was thinking too about the 882 heads. The guy that built it for me said he just ported and polished.. I was hoping they were not the 76cc ones.
Old May 9, 2014 | 10:15 AM
midias's Avatar
Re: Hp estimation
All 882 heads are 76cc, they are probably the best of the smog heads but they cannot hold a candle to a stock vortec.
I have had them and would not recommend them for any decent cam that light higher compression
Old May 9, 2014 | 10:36 AM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: Hp estimation
Awesome.. well I hoped to not have to take the valve covers off since I had this thing just built
Old May 9, 2014 | 10:57 AM
midias's Avatar
Re: Hp estimation
They will still work and are better than many of the 80s heads and other smogger heads
They are like getting kicked in the nuts with a shoe vs a boot
Old May 9, 2014 | 11:03 AM
AutoRoc's Avatar
Engine: Vortec 4200 Inline 6 PT70 Turbo..
Transmission: 4L65E
Re: Hp estimation
300
My car is all of that guys signature quote.
All springs are cut at some point...
GM should have made a factory access hole...
Riddler award show cars have a thin skin of bondo...
maybe someday my car will be as cool as his.....................
Old May 9, 2014 | 11:07 AM
midias's Avatar
Re: Hp estimation
What stall are you running with that cam? You will probably want 2500-3000
Old May 9, 2014 | 12:14 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: Hp estimation
Ok so I just found that they are the casting 3927185 which is a goo70cc head, same valves as mentioned before. What does that do for me, lol
Old May 9, 2014 | 12:15 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: Hp estimation
Currently a 2500 stall
Old May 9, 2014 | 02:26 PM
midias's Avatar
Re: Hp estimation
in stock form I would probably take the 882 head over the 185. The 185s were low end small block heads. Better off getting a set of world products S/R heads new and assembled for 700
Old May 9, 2014 | 03:23 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: Hp estimation
Awesome, looks like lose lose. Did I lose here: I got a new zz4 short block 30 over carb to pan with above mentioned parts installed for 2500 bucks.. win or lose?
I had. 305 tbi before
Old May 9, 2014 | 03:29 PM
midias's Avatar
Re: Hp estimation
It will be a big step up from the 305.
The zz4 block is a good one and they are expensive if this is what you got. then you did decent.
http://www.jegs.com/i/GM+Performance...FUQaOgodSFMAWg
I would not have put in a flat tappet cam considering the block can accept a roller. Also the heads seem like something he had around the shop.
You did not get boned but you may have been able to do better
Old May 9, 2014 | 03:41 PM
89newfun's Avatar
Car: 1989 Camaro
Engine: Sbc 355
Transmission: TH350
Re: Hp estimation
Yes thats the ticket. Here is the image of my short block, can zoom into the block number next to piston read out.
Old May 9, 2014 | 04:34 PM
FRMULA88's Avatar
Car: 1988 Formula
Re: Hp estimation
Originally Posted by AutoRoc
300
FWIW GM engineered these cars to last 10 years or 100,000 miles.
An access panel would have cost more. Same reason why OEM cars normally do not have drain plugs on transmissions and rear ends.. (most people never bother) and when these parts are shot... normally the rest of the car needs repair work anyway.
that being said if the fuel pump fails you drop the tank and replace it.. if you used a good pump it should be good for at least another 100.000 miles.
now if the tank is 20 years old and full of rust and crud that will damage /clog a new pump is short order so you have the tank boiled out or replaced with new at the same time.. either way no need for an access panel.. how often do you need to replace the pump if you do it right?
I never cut my OEM springs.. I did have to my front drag race springs.. (1 coil) but these were "universal fit" some cutting req'd..
A think layer of filler is totally fine... skim coat... show car paint jobs always get s little skim coat of "glaze" while blocking out the primer..
I think that was directed to "bondo barge" where there is more body filler on the car than sheet metal..
still a low class shot .... don't feed the trolls LOL!
Old May 15, 2014 | 03:21 PM
articwhiteZ's Avatar
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
Re: Hp estimation
Originally Posted by init4fun
Hey Mr. Visitor , did you seeWhat's up with the nasty dis of TGO in your sig ? You got NO right lumping the entire site together as folks who take the lazy way out of all repairs and I for one think your a jerk for doing so !
lll
Now now...if ya go and poke the troll...he will try to comeback at ya with a lame a$$ comeback.. of a 10 year old (edit in a girls left handed throw..)
remember...some guys like to Blow there own Horn...and he loves to Blow ....
little boy blew......he needs the money..
Edit to apologize two any girls...reading this.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
skip91
Sep 24, 2015 03:29 PM
ULTM8Z
Sep 16, 2015 09:15 AM
bellez77
Sep 5, 2015 08:39 PM
Trevor K
Jul 12, 2001 01:44 PM
