Idling issues
Old May 11, 2014 | 10:49 PM
T-rev100's Avatar
Car: 1988 IROC-Z28
Transmission: TH700-R4
Idling issues
'88 Iroc with the L98, started having idling issues last year really bad to the point I almost got stuck, car just DID NOT want to start and stay running. It ran at very low RPMs and once I'd tap the gas it'd die. Brought it into the Chevy dealership and all they could tell me was maybe it was the IAC or MAF, so in brought it home and replaced the IAC, ran a little better but now I still have to keep my foot on the gas until it warms up awhile or it will just die, sometimes it'll run fine for awhile then bog down while idling, while driving it runs just fine. Just looking for a second opinion before I go replacing the MAF =\ thanks.
Old May 13, 2014 | 05:55 AM
Vader's Avatar
Re: Idling issues
The ECM is very intolerant of MAF errors. If the signal is lost or out of the acceptable ranges for about 600mS the fault code will set. If there are no codes, you might want to look elsewhere. If you want to test the MAF to be certain, used a voltmeter at the MAF terminals B and C:
Old May 13, 2014 | 04:38 PM
T-rev100's Avatar
Car: 1988 IROC-Z28
Re: Idling issues
That's the reason why I'm so lost on this, it DOES throw a code but when I check it, code 12: system normal. Every time. Haven't checked the MAF with a voltmeter yet I'll have to see how that goes.
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
bamaboy0323
Sep 3, 2015 06:07 AM
mike_c
Aug 27, 2015 04:32 PM
IroczFan
Carburetors
Aug 18, 2015 05:19 AM
