Lights flickering, corroded fusible link
Car: 86 Trans Am WS6
Engine: 383 stroker
Hey guys, so I finally got my 305 tpi running steady with a good idle, Ive always had flickering headlights and an odd volt issue, the car would read 12 volts while driving. I replaced the alternator and belt recently which put brought the volts up to 14, all seemed to be going great until I noticed the volts dropped down to 12.5 (checked with volt meter). Then I noticed the head lights shutting off and coming back on while driving at night, this was unaffected by rpm and was very random. I started reading about a fusible link on Thirdgen so I took a look at mine and noticed the P.O wrapped fusible link in tons of electrical tape, I took it off and the link was completely corroded and flaky. The two wires coming off the link are also taped and show exposed wiring, what's the best way to repair/ replace this whole wiring section? Would this cause the problems I described earlier?
Engine: 383 stroker
Re: Lights flickering, corroded fusible link
Can anyone tell me what this is exactly? Any way to bypass/ replace it?
Car: check
Engine: check
Transmission: check
RBob.
Car: check
Engine: check
Transmission: check
So cut the wire back some to get to a good area, crimp, solder, and seal new links into place.
And yes, bad a fusible link can cause the headlights to go out.
RBob.
Engine: 383 stroker
I believe the corroded part is the cap that covers the fuse, definitely replacing when I get home, thanks a ton
Engine: 383 stroker
At a minimum need to purchase some fusible links to replace the fried ones. On the stock ones the round cylinder is covering the splice between the link and the actual wire it is protecting.
RBob.
RBob.
Engine: 383 stroker
I've never seen something like this, can someone tell me what this is?
db057
Aug 11, 2015 10:11 PM
