rear end loose and swaying
Old May 21, 2014 | 11:56 PM
MyCarIsSlow's Avatar
I was coming home and all of a sudden it felt as if my car was fishtailing. I slowed down and noticed a ticking and kind of screching noise from the drivers. I limped in home and shook the rear of my car and it felt like the whole rear axle was gonna fall out. Any help?
Old May 22, 2014 | 04:29 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: rear end loose and swaying
Defintely something broken, get under and look while someone wiggles the car around. Panhard rod bushings maybe?
Old May 22, 2014 | 07:29 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
Did you try looking under the car?
Old May 22, 2014 | 05:07 PM
Yeah I did this morning cause it was dark and I couldnt find a light.. but anywho there is this piece that runs behind the differential. I dont know what it is tho?
Old May 22, 2014 | 05:36 PM
midias's Avatar
probably pan hard bar. Use your phone and take a picture
Old May 22, 2014 | 05:45 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
Axle/Gears: 4.10 D44
Panhard bar? The red item in the picture. That is the part that locates the axle from left to right. Yeah, if that broke, the axle would be wiggling back and forth under the rear of the car. Better question: what broke? The bar? bolts holding it? Or the mount?
Old May 22, 2014 | 06:29 PM
Yeah that might be it. Its broke right in the middle. Could you weld it? Or is it an easy part to change? And how do you upload pictures from your phone?
Old May 22, 2014 | 06:50 PM
MoJoe's Avatar
Car: 87 IROC
Engine: L31 350
The panhard is a major suspension component. Whatever caused the stock piece to fail (rust, impact damage) probably means welding might be good enough to get you home. Get a replacement. The aftermarket (Founders Performance) has some inexpensive replacements.
One bolt on each end. Doesn't get much easier than that. Nuts and bolts probably need plenty of PBBlaster or LiquidWrench to break the rust bond.
Don't know about phone uploads.
Old May 24, 2014 | 12:29 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
yep panhard bar or bolt broke
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
