Hot fuel filter
Old May 22, 2014 | 12:26 PM
Lab Rat's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7
Hot fuel filter
What would cause a fuel filter to get hot on an 88 350 tpi? New fuel pump and filter. The filter is in the stock location.
Old May 22, 2014 | 07:36 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: Hot fuel filter
The engine.
Old May 22, 2014 | 08:23 PM
Lab Rat's Avatar
Engine: 5.7
Re: Hot fuel filter
How would the engine cause the fuel filter to get hot?
Old May 22, 2014 | 10:32 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Hot fuel filter
Compressing fluids increases the temperature of the fluid. As it goes through the pump, it will heat up. Basic laws of thermodynamics.
Old May 22, 2014 | 10:35 PM
Lurbie's Avatar
Car: 89 Camaro
Engine: Dart SHP 400-Holley Terminator EFI
Transmission: Tremec T56 Magnum F
Axle/Gears: Strange S60 3.55:1
Re: Hot fuel filter
You've also got fuel returning to the tank after it passes through the regulator, picking up engine heat and going back to the tank.
Old May 23, 2014 | 05:58 AM
Lab Rat's Avatar
Engine: 5.7
Re: Hot fuel filter
So, it's normal for the filter to get hot?
92camaroJoe
Jul 29, 2023 07:57 PM
1992 Trans Am
May 10, 2023 07:19 PM
specialized
Jun 18, 2022 09:26 AM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
