gas since 97. what to put in now?
Old May 23, 2014 | 08:00 PM
IowaStreets's Avatar
Car: 06 Dodge Charger Daytona
Engine: 5.7 HEMI
So car was last serviced in 97. So I assume the gas is that old also however it runs just fine somehow. What kind of gas should I get to ”clean up" the carb and engine all together?
Old May 24, 2014 | 12:25 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Re: gas since 97. what to put in now?
well nothing is going to be better then dropping the fuel tank and cleaning it out and pulling the carb and cleaning out the fuel bowls and stuff but the auto parts stores have many types of fuel system cleaners.
Old May 26, 2014 | 03:33 PM
Engine: 5.7 HEMI
Thanks I decided to drop the tank and since its an external block mounted pump I sprayed cleaner on it and Through-out the carb. Sounds so much smoother no more struggling thanks!
Old May 27, 2014 | 06:19 AM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Glad to hear you did it right and didn't try to run that gunk through the fuel system!
92camaroJoe
Jul 29, 2023 07:57 PM
86White_T/A305
Aug 17, 2015 12:16 AM
92camaroJoe
Aug 13, 2015 06:07 AM
