Car will only start on first try and when it cools down?
Old May 23, 2014 | 08:08 PM
rizo916's Avatar
Car: 1989 Camaro Iroc z
Engine: 5.0L 305
Transmission: 5 Speed Manual
Axle/Gears: 3.08
89 Camaro with a 305 TPI manual, the car did not want to start after driven for a little while. Car will start up perfectly the first try but if I stop the car anywhere (like for gas) the car starts but very slow crank. Now if this happens a second time (I stop for something else) my car will crank slowly but will not start until it cools down. I just replaced the starter this morning and the problem continues. Not even 10 minutes driving on new starter and issue happening. Usually if I keep trying to crank the car will give up and stop cranking. Then I have to wait about an hour for a slow crank start. Car has fairly new post, terminals, and starter cables. Also the starter I replaced was in good condition.
Old May 24, 2014 | 12:22 AM
92rsvortec350's Avatar
Car: 92 rs z28 clone
Engine: forged 350
Transmission: 700r4 fully built
Axle/Gears: moser axles eaton posi 3.73 gears
Re: Car will only start on first try and when it cools down?
I had this problem and it was heat soak on the starter I used to carry a sports bottle of water and I could squirt water on it and it would start I put a remote solenoid on it and no more problems. but mine would just click until it cooled.
midge54
Dec 27, 2019 04:14 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
killer777
Aug 8, 2015 02:47 PM
