eectric fuel pump issue
Old May 26, 2014 | 05:50 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
I have the summit brand electric fuel pump 110gph. the issue im having is that when I drive the pump quits making noise and fuel pressure drops, but the idiot light I have installed stays on. if I mess with the switch off on off on etc it finally kicks on. is my pump on its last leg? and would it be worth going back to a block mount fuel pump?
Old May 27, 2014 | 04:13 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: eectric fuel pump issue
what circuit is the idiot light on?
are you using a relay ?
checked it's operation ?
will the pump run if you hotwire it direct to the battery ?
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
