Have 82` Firebird with a 4 cylinder that won`t start?
Old Jun 1, 2014 | 07:27 PM
Thirdgendriver's Avatar
Car: 85` Camaro
Engine: 355 .3 bored, cammed
Transmission: 350 turbo trans
Ok, so my brother did a tune up on my car, changed spark plugs and wires. It ran really bad then died. We got it back home and saw the wires were in the wrong order. Fixed it and now my car is just keeps trying to turn over, with a dark grey to black exaust. My dad has been a mech. for over 30 years. He is stumped. Please help.
Old Jun 1, 2014 | 08:09 PM
ex-x-fire's Avatar
Re: Have 82` Firebird with a 4 cylinder that won`t start?
Did it run good before (better then now) the tune up. Double check the firing order. Maybe he cracked a spark plug.
Old Jun 1, 2014 | 10:27 PM
Car: 85` Camaro
It ran like a charm before. The order is correct. I have a manual and doubled checked. The plugs should be fine. Got spark.
Old Jun 4, 2014 | 04:28 PM
Car: 85` Camaro
It still doesnt want to start.
Old Jun 5, 2014 | 06:06 AM
ex-x-fire's Avatar
If it ran fine before the tune up then now it doesn't, what does that tell you?
Pull #1 spark plug, turn engine over by hand till it's at TDC compression stroke. Pop the cap off of the distributor, the rotor should be pointing at the area where #1 spark plug wire should be.
If that's ok, then check for spark & fuel. This is all basic stuff.
theshackle
Mar 5, 2017 06:37 PM
Brcharrelson
Aug 26, 2015 07:47 PM
db057
Aug 22, 2015 08:17 PM
justin57
Aug 20, 2015 07:05 PM
Randomtask2
Aug 13, 2015 01:57 AM
