4th gen fuel tank in a 3rd gen?
Old Jun 12, 2014 | 07:35 AM
gearheadotaku's Avatar
Car: '91 Firebird
Engine: 305 TBI w/LT1 cam
Transmission: T5 swapped in
Axle/Gears: 9 bolt 3.27 w/discs
My 3rd gen suffers from fuel starvation in hard corners when the tank is 1/3 or less (typical right?) My 4th gen doesn't have this issue at all. I can toss it around nearly on "E" with no problem. Can I use a 4th gen tank in my 3rd gen car? The body and shape of the tank look 1/2 way close... A true 1LE 3rd gen tank is way too expensive to consider.
Old Jun 12, 2014 | 07:54 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 4th gen fuel tank in a 3rd gen?
The 4th gen tanks fit just fine. 98-02 were from ls1 cars with the 99-02 being plastic. They have no baffles but do have a fuel bucket around pump that supposively stays filled.
The 98 was metal and had baffles.
93-97 i believe were metal but no idea on baffled or not.
My iroc factory tank had fuel starve issues on hard cornering as well with low tank level. I think the 1LE tanks had more baffling and worked better but no idea where to get them.
I love the plastic 4th gen ones as you can drop tank in minutes as the fill neck is rubber hose and is easily moved as you bring tank down. No wrestling neck out
Old Jun 12, 2014 | 11:01 AM
jazzdadss's Avatar
Car: 1989 IROC LSX
Engine: Swapped LS6 Forged by LME
Transmission: 4L65E
https://www.thirdgen.org/forums/ltx-...k-plastic.html
Everything you ever wanted to know.
mustangman65_79
Apr 14, 2017 05:37 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
AkDrifted
Aug 17, 2015 07:45 PM
redmaroz
Aug 16, 2015 11:40 PM
Eagle223usa
Brakes
Aug 14, 2015 09:24 AM
