smokes at start up...bad!
Old Jun 12, 2014 | 08:32 PM
mooch1's Avatar
Car: 1985 camaro Z/28
Engine: 305 V/8 4bbl carb
Transmission: T5 WC
Axle/Gears: 3-23 posi with 4 wheel discs
hi , i recently got a 1985 Z/28 305 4 bbl stock...at start up when cold & the chock comes on it smokes real bad!! white- grey smoke ...i can pollute the whole street ...it runs fine..doesn't run rough..choke stays on then i give gas and the choke comes off and idles fine and smooth...clear oil..clear prestone...the car just runs fine except that cloud of smoke at start up ,,then as it runs the exhaust smoke is gone and back to normal...bad gas?? the only thing i can think of is that i put some of that grape smell stuff in the tank for the exhaust fumes since it is stock but has no cat...can that be it? it was added with a full tank of gas...i thougt maybe a head gasket?? but it doesn't mix prestone/gas...runs great and has the regular power it should..any ideas would be appreciated...thanks in advance.
Old Jun 13, 2014 | 02:43 AM
83ZZZ28's Avatar
Car: 1983 Z-28.. Owned since 1985
Engine: LG4 (H) Vin Code
Re: smokes at start up...bad!
It's not bad gas or head gasket. What you have is an inherent problem with the 305's. VALVE STEM OIL SEALS .
It's about a 2 hour job, good parts will run you around $50., plus what ever level of new Valve Cover Gasket'$ you choose.
If you wanted to make money to pay for repair expensives...since you live in Montreal, charge your neighbors for Misquito Control. They pay you 5 bucks for everytime you start the Camaro up.
Rod
83ZZZ28
Old Jun 13, 2014 | 04:10 AM
mooch1's Avatar
Transmission: T5 WC
Rod
83ZZZ28
thanks for the response...i thought it could of been that ,,,but wow it smokes really bad! i mean the whole street is in smoke , just for about 10 minutes or less though... then as it runs it stops to smoke..it runs fine and it doesn't shake or anything like that...it just started doing this recently..it always smoked a bit on start up , but now it's bad,,,i can do this myself? a sticky anywhere to help with directions...thanks again
Old Jun 17, 2014 | 06:29 PM
MustangBeater20's Avatar
Car: 1991 Camaro RS
Engine: Built TBI 350
Axle/Gears: 3.42 Posi
Ya it's the valve seals.. My 305 TBI does it too.
Old Jun 17, 2014 | 08:54 PM
SouthSide2's Avatar
Car: 1990 RS Camaro
Engine: 406
Transmission: TKO 600
Valve seals are bad and maybe oil return blockages. Do a search here "valve seals"and read. You will find great advice, and you may find you'll need more tools or a pro to fix this common problem. It's all here, just look. Or maybe you need a new, more powerful engine to fix this sick old engine problem you have been living with for far too long. Happy to help if your really at a loss, but only to a point
Old Jun 18, 2014 | 05:34 AM
mooch1's Avatar
Transmission: T5 WC
not looking to replace the engine, if i can just replace the valve seals,,,then i will do that..thanks.
is this something i can do at home?
Old Jun 18, 2014 | 10:16 AM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
it would be better for you, in the long run, to pull the heads and send them to a machine shop for a rebuild.by the time the valve stem seals go away .usually the valve guides ,seats,and springs need attention as well.
bryan623
Mar 22, 2021 06:43 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Red iroc-z 305
Sep 30, 2015 05:22 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
86White_T/A305
Aug 17, 2015 12:16 AM
