Persisting valve lash problem.
Old Jun 13, 2014 | 03:13 PM
James Sutton's Avatar
Car: 1991 Camaro RS yellow
Engine: was '91 V6, now '89 5.7/355 TPI
Transmission: 4 speed automatic
Axle/Gears: Moser 3.73 with zexel posi
Have tightened valves three times. Each time, great power for a mile, then a pop, then some loss of power; engine warning light goes on until next start, then off. Car still runs, but a mite rough.
Had previous overheating problem, which caused push rods on #1 to break & #3 to bend. Replaced rods and engine head gasket. No probs with push rods since.
Engine is a "Wonder." Weirdly, bolt holes at #1 and #7 pistons are drilled into water jacket. Welded stud to #7, but not enough clearance to do same at #1. Threading tape stopped the leak there.
Prior to swapping engines, had "Wonder" engine block cleaned, crack checked, honed and bored along with the rotating assembly balanced.
Battery was bad; replaced it; problem persists: can't keep #1 valve from lashing or in adjustment, as if there's too much piston pressure. Engine is running rich.
What's my problem? Springs? Wrong valve clearance? Fuel injectors? Would one-piece rocker/push rods solve this problem? Some burning on distributor leads to spark plugs.
Not sure I've given you enough or too much info; I'm a (very old) English major.
Old Jun 13, 2014 | 05:18 PM
Re: Persisting valve lash problem.
Common cause of this, is simply, wore-out rocker nuts; backing off.
Go to the hardware store and pick up 16 3/8"-24 (fine) nuts. Use em to jam the rocker nuts.
Old Jun 14, 2014 | 04:31 PM
Thanks, Sofa; I'll try it.
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
sandman92084
Sep 12, 2015 10:27 PM
383cam
Sep 9, 2015 06:01 AM
dimented24x7
Sep 6, 2015 03:51 PM
