Hard time starting and
Old Jun 14, 2014 | 02:54 PM
Wesotsuki's Avatar
Car: 89' Iroc Z
Engine: LB9
Transmission: 5 speed manual - warner gear
I have a 89' iroc-z 5.0 TPI.
No MIL or CEL are illuminated
Nor codes stored
Cold start, stalls first 2 minutes of operation.
When I go to start my engine, it takes a while to start, in doing so I step on the accelerator pedal and then it fires right up. But then stalls out. When trying to drive, it could go a distance, no stumble while on the accelerator pedal, but when coming to a stop it stalls.
Maybe its not going into closed loop? Throttle plates not opening enough at idle?? Or.. Possible faulty ECT, intake valve deposits.
Recent work before this started happening.
New throttle body
I'm guessing when I installed the new throttle body, messing with the idle may have some sort of play into causing this issue.
Any help would be awesome.
Also what could cause a accelerator cable to stick, no it's not dirty or getting stuck anywhere near the firewall, or at then pedal. I even shorten the cable and it's still getting stuck. But keep in mind this only while KOER.
Last edited by Wesotsuki; Jun 14, 2014 at 03:46 PM. Reason: Hit post by accident, on an iPad.
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
cstrobel65
Aug 15, 2015 10:19 AM
92camaroJoe
Aug 13, 2015 06:07 AM
apie2546
Aug 8, 2015 07:12 AM
