No Oil
Old Jun 21, 2014 | 10:31 PM
mr z28's Avatar
Car: 74 Nova prostreet 87 Iroc Z28
Engine: 427 671 blower 350 Built
Transmission: 700R4 both
Axle/Gears: Dana 60 an a 323 posi.
No Oil
Hi Guys I have 350 went to prime the motor today an all cyl. are oiling but 1 I have about 60 psi could someone tell me why? all new everything. Thanks
Old Jun 22, 2014 | 04:16 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: No Oil
I'm no engine rebuilding expert but I think 60-psi at drill motor speeds is pretty decent.
If I'm not mistaken, if you're priming the engine without one of those tools that takes the place of the distributor body then there is a huge oil leak to the top end that might be contributing to the "low" oil pressure.
Old Jun 22, 2014 | 08:54 AM
Re: No Oil
Trick question?
Because the oil pump is turning!!
Seriously, I don't see a problem. Not sure what you're expecting instead?
Da Heights eh... used to live up that way in the early 60s. In Morgan Park & the orphanage in Glenwood, had family around Crete. Da Heights ain't what it used to be, is it.
Old Jun 22, 2014 | 09:07 AM
mr z28's Avatar
Re: No Oil
I DONT HAVE THE ROCKER ARMS ON BUT I DONT THINK THAT THE PROBLEM WHEN THE OTHERS ARE PUMPING.
Old Jun 22, 2014 | 09:09 AM
Re: No Oil
Not sure what that means.
Old Jun 22, 2014 | 12:06 PM
rusty vango's Avatar
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
Re: No Oil
a gen 1 small block,right? well then, oil comes up through the push rods to oil the rocker arms. finish your engine. THEN prime
Old Jun 23, 2014 | 07:47 AM
OrangeBird's Avatar
Car: 1989 Firebird
Re: No Oil
If I understand your post correctly , you have 60 PSI oil pressure when spinning the oil pump with a drill , and all but one of your sets of rockers are squirting oil , is this correct ?
jrdturbo
Mar 31, 2016 02:58 PM
skinny z
Oct 5, 2015 06:23 PM
meeklay812
Oct 1, 2015 03:46 PM
Gordonr1973
Sep 29, 2015 11:59 AM
