car wont start
Old Jun 26, 2014 | 02:02 AM
88camblue's Avatar
car wont start
I have a 1988 camaro V6 2.8L, problem is it wont start, i replaced the fuel pump first ran for about a month no problem then didnt want to start agian, so i had to replace the relay, worked for about 2 months good then same problem didnt start. banged on the gas tank with a rubber mallet did the trick worked for about 3 months until it happened agian. which i banged on the gas tank again and started working for 1 day, now it wont start i can hear the fuel pump turn on when i turn the key, checked fuel filter not clogged, checked relay for continuity it works good. Dont know what to do help please!
Old Jun 27, 2014 | 07:14 AM
Vader's Avatar
Re: car wont start
Welcome Aboard!
It would be good to test the fuel pressure before banging on the tank any further. If you do not have a pressure gauge you can "borrow/rent" one from some of the chain parts stores.
Old Jun 30, 2014 | 10:13 PM
88camblue's Avatar
Re: car wont start
well there was a wire going up to the gas tank,, cleaned the plug out and put it in and seemed to work, but now when i drive it it turns off when i drive randomly. has to be eletrical problem, i can hear the pump turn on... any suggestion?
Old Jul 2, 2014 | 06:59 AM
Vader's Avatar
Re: car wont start
Did you get a fuel pressure measurement yet?
Old Jul 2, 2014 | 09:15 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
Top Fuel Advice
Then find out where it’s losing power.
This quick-to-build assembly will tell you.
Grab a piece of sheet metal, drill a few holes, mount a few LEDs and you’re good-2-go.
You can use LEDs with built-in resistors so they’re ready to use with 12 volts.
Wire A — Connect to pin A of the pump relay.
Wire D — Connect to pin D of the pump relay.
Wire E — Connect to pin E of the pump relay.
Wire P — Connect at the pump.
Mount the panel in the cockpit.
Double-sided tape will work because it’s a temporary panel.
Now, when you’re driving and the engine cuts out, you merely have to glance at the panel to see where the problem is.
Happy Racing !
8 Wheels Corner Better Than 4, If You’re On The Outside You Have Fair Warning
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
86Base
Aug 8, 2015 01:34 PM
L98GTA87
Aug 5, 2015 11:02 PM
