LOOSE CLUTCH PEDAL!!!!!
Car: 87 iroc z
Engine: 383 stroker
Transmission: 5 speed, bought the car July 1 so.?
Axle/Gears: Stock tran and rear end
Bought a 87 iroc-z two months ago, was driving home today and the clutch pedal will move side to side, at first could feel a slight hang up with the pedal then got obviously got worse and looser with more shifts. If I hold the clutch pedal firmer to the right, with my foot, while shifting, it felt more stable, I'm hoping for a loose bolt
?????? Much appreciated to any one with any thoughts to the possible problem. Thank you
?????? Much appreciated to any one with any thoughts to the possible problem. Thank you Supreme Member
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Re: LOOSE CLUTCH PEDAL!!!!!
I had the clip that holds the rod to the pedal assembly break, then several shifts later, no clutch at all. slip back on, get a dozen or so more shifts and fall off. Some special plastic clip, tried to get one, ended up just using a simple washer and a 5/16" E-ring
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
?????? Much appreciated to any one with any thoughts to the possible problem. Thank youJoined: Sep 2005
The pedal rides on the pivot bolt, via 2 little plastic bushings. They're real thin (probably not more than .030" if even that), grey, maybe an inch in diameter with a sort of flange on the end.
You used to could get them in the Help! aisle at stores that have that. Even AZ. Not sure if they still have them but that's where I'd start looking. Rockauto might be another place to try.
Car: 87 iroc z
Engine: 383 stroker
Thanks gonna check that out as well, it was the 305 5sp, original clutch and break assembly so I'm curious if its the bushings because that's where the clutch moves everywhere.
