Why does my car smell bad??
Old Jul 7, 2014 | 09:36 PM
coltonfox34's Avatar
Car: 1986 Z28 Camaro
Every time I start my car, I see white smoke come out of my tailpipes and i mean a lot of smoke but it's only when i start it. While I'm driving it, i smell carbon monoxide the whole time. What could be the problem?
Old Jul 7, 2014 | 11:28 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Why does my car smell bad??
Carbon monoxide doesnt have a smell. The smoke sounds like valve seals which is mostly an inconvenience and shouldnt hurt the engine unless it's extremely bad and you manage to hydrolock it or something.
Old Jul 7, 2014 | 11:32 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
the exhaust smell is probably a leak in the exhaust system,do you hear a ticking noise?
Old Jul 8, 2014 | 09:04 PM
eshaw's Avatar
Car: 16' Silverado
Engine: 5.3
White smoke tells me that your burning coolant.
Old Jul 8, 2014 | 10:05 PM
It's not coolant.
It's oil.
It needs valve guide seals, like every other old SBC. Piece o cake. take an afternoon and knock it out.
Old Jul 9, 2014 | 07:19 PM
Well it is oil burning. Then what is the gas smelling from the exhaust coming from. I do have two little leak holes in the pipe going in the exhaust but that shouldnt why its smells right or do i have a blown head gasket??
Old Jul 11, 2014 | 08:34 AM
Car: 1992 Camaro RS
Yes. That's why you smell exhaust.
Old Jul 11, 2014 | 10:41 AM
red rock's Avatar
Car: 1987 iroc
Engine: 383 TPIS intake, Dyno Don headers
Transmission: 700R4 w/Pro-built Auto/transgo 2-3
Axle/Gears: 3.27/3.70 borg warner 9 bolt
Hey Colton, Don't over think the obvious. An exhaust leak and a little rich running engine will give you a nasty headache. Sounds like some needed maintenance is in order. Giver a good tune up, fix the exhaust leak, and live with the leaky valve seals till you can fix them.
Old Jul 11, 2014 | 03:42 PM
bop11's Avatar
Car: 1988 GTA
Engine: VIN F 305 TPI
Transmission: AUto
Fix that exhaust leak ASAP or you might not live long enough to fix those leaky valve guide seals.
bryan623
Mar 22, 2021 06:43 PM
maroe624
Apr 16, 2017 08:29 AM
86IROC112
Apr 9, 2016 10:20 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
