How do I test fuel injectors if the problem is intermittent?
Old Jul 17, 2014 | 02:56 PM
Fronzizzle's Avatar
Car: 1985 IROC-Z
Engine: 383
Hello all,
I've posted before about a chugging/hesitation issue I have sometimes on my 1985 Camaro IROC-Z (383 stroker, HSR setup) and partial throttle. The problem is really bad when the engine is cold, then gets better (but never fully goes away) when the car gets hot.
I've always suspected that the problem was fuel-related, and after talking to a car-guy friend of mine today we came to the conclusion that one thing that might cause it is a bad fuel injector (the fuel pressure is fine).
My question is, how do I go about testing the injectors if the problem is intermittent? The car idles fine, so having it run and pulling the wires for each injector wouldn't work. And as I said, once the car is warmed up the problem just about goes away.
Separate of replacing the injectors one at a time, is there a way to check them to see if one is bad/going bad/plugged?
Old Jul 17, 2014 | 03:02 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Re: How do I test fuel injectors if the problem is intermittent?
Have you tried this?
bryan623
Mar 22, 2021 06:43 PM
Jae992
Aug 27, 2015 09:07 AM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
Firechicken86
Aug 12, 2015 10:07 PM
