Seafoam - what vacuum line should I use?
Car: 1982 Firebird Trans Am
Engine: LU5 Crossfire (305)
Transmission: THM200C
Just about to use Seafoam for the first time and instructions state that it should be introduced directly into the engine through a vacuum line that serves all cylinders. For a Crossfire motor (LU5), does the vacuum line that connects to the MAP sensor serve all cylinders or is there another one that I need to use?
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Seafoam - what vacuum line should I use?
If you're interested in cleaning injectors and cylinders you could put it in the gas. easy and worked great for me. Engine improved a huge amount after two or tankfuls.
Car: 89 trans am / 67 gto
Engine: 350TPI
Transmission: AUTO
Axle/Gears: 3.27 9 bolt
Thanks for the good advice. I decided to introduce Seafoam into each TBI through the port at the lower right of each unit and also added it to the gas. Used vacuum tubing and a t-fitting so that the TBIs would be fed evenly. (see picture) Went to a remote area last night, and it worked as advertised. Drove the car to work today and it's a real nice improvement. Will continue to use in the gas for the next few fill-ups. Much appreciated.
Doobie52
Sep 11, 2015 06:19 PM
