Test drive tonight 1 problem...
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
So I took out my 83 z28 tonight for its first longer test drive in quite a while after doing a ton to it. Car drove and ran great but with 1 main problem. My speedometer didn't seem to read right at all would barley go above 25mph and the needle would just kind of dangle around. Also my tach which I have read is a problem with these cars was reading probably twice what it actually was. Tomorrow I will be taking the dash apart to do some investigating but just trying to get some ideas of what could be wrong or what to look for thanks....
Car: 1984 Camaro Z28 H.O 5.0
Engine: 5.0L
Re: Test drive tonight 1 problem...
The speedo problem could be caused by using the wrong transmission adapter or drive gear or sleeve or wrong size wheels and tires or could just be a faulty speedo head. The tach problem is most likely a failed tach filter.
Here's a good explanation of the speedo drive gears.
http://www.camaros.net/shop/speedo.html
On my 84 Camaro my tach filter looks similar to this one and is located on the fire wall to the driver's side of the distributer.
http://www.elcaminocentral.com/users...ch_filter1.jpg
Make sure the body of the tach filter is grounded well or it won't work.
http://i1234.photobucket.com/albums/...tachhookup.jpg
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Thanks for the info. I will check this filter where would I be able to get another if I needed to replace. Also one of the things I did was replace factory distributor with a MSD street fire one so would that have anything to do with it?
db057
Aug 11, 2015 10:11 PM
