bouncing vacuum at idle help
Old Jul 22, 2014 | 12:29 PM
91 camaro racer's Avatar
Car: 91camaro rs,2014 silverado 5.3L
Engine: 5.7Lcarb,5.3L
Transmission: 700-r4, 6L80
Axle/Gears: strange 3.73's
here is a video i shot today of my problem. the idle vacuum bounces very fast at idle. when driving it is very steady. specs of the engine are:
chevy 350 lunati cam ( .458 lift both sides, 110 LSA, intake center line 106, adv duration 284/284, duration @ .050 218/218) holley 600 cfm carb
edelbrock performer rpm intake, TFS 195 cylinder heads.
a quick run down of what is going on in the video, sorry for the horrible quality it is a cell video.
vacuum on cold start bounces from 8-12
engine rpm cold start out of gear 500 rpm
driving at 20 mph steady ~16"
vacuum at warmed up idle out of gear bounces 12-14
rpm warmed up out of gear ~750
vacuum warmed up in drive 9-12
rpm warmed up in drive 600
here is the video.....
Old Jul 22, 2014 | 01:00 PM
Re: bouncing vacuum at idle help
what could be causing this? i am trying to adjust the mixture screws but it is difficult when they bounce like this.
Old Jul 22, 2014 | 08:06 PM
Berlinetta00's Avatar
Veteran: Marine Corp
Car: '84 Berlinetta
Engine: ZZ4
Transmission: BTOD stage 3
Axle/Gears: 3.23 posi disc
A sticking valve is normally the culprit when the vacuum is bouncing that badly. I had it do the same thing one time with a worn out lifter. What happens is the vacuum signal for most of the cyl. is normal, but when the cyl with a bad valve is on the intake stroke, the vacuum signal changes from normal. Pull the valve covers and run it, you could have anything from a bent push rod to a bent valve.
Old Jul 22, 2014 | 08:55 PM
thanks for the advice. what all should i look for when running without valve covers? bent pushrod should be easy to see but what about a bent valve? anything else to look at? i will be checking compression and valve adjustment also.
Old Jul 26, 2014 | 01:05 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
A bent valve wont seal to the valve seat, meaning you wont have compression on that cylinder.
Old Jul 26, 2014 | 01:26 PM
Did a compression test last night...
1** 160
2** 160
3** 170
4** 165
5** 178
6** 170
7** 165
8** 170
Old Jul 26, 2014 | 02:37 PM
since they are all withing 10% of each other i would say that my rings and valves are good to go right?
Old Jul 26, 2014 | 02:54 PM
and this was on a cold engine. dont think the neighbors would like a 1 am alarm clock...
Old Jul 26, 2014 | 04:21 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
I have almost the same cam in my 305 in the Corvette and it bounces the same way. Makes a touch more vacuum than you though. Probably a tuning issue rather than a mechanical one. With the 110* LSA and 218/218 @ .050 its not going to have a low smooth idle with a ton of vacuum. It will have a moderate idle at 750 rpm and it will definately have some lope.
What is your timing set at? Is your vacuum advance hooked up? Is it hooked to manifold vacuum? Have you tried screwing in your idle mixture screws, bringing them out evenly 2.5-3 turns and starting over?
Old Jul 26, 2014 | 04:50 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
See this link:
http://www.secondchancegarage.com/public/186.cfm
A vacuum gauge is one of those forgotten diagnostic tools.
Old Jul 26, 2014 | 06:34 PM
yeah i have been talking to lunati about this too. they say the flicker of the needle is fine due to the cam but the vacuum is low, should be at 16" or so at a idle rpm of 850 out of gear. my timing is 12-14 initial with the advance disconnected. when it is hooked up i have it on the ported vacuum. i will adjust my mix screws again tomorrow.
Originally Posted by paulo57509
See this link:
i have seen this before. i think i just need to get my mix screws dialed in
Old Jul 27, 2014 | 08:00 PM
Just messed with my timing and screws. Raised initial advance to 16, played with the screws and got it pretty steady at 14.5-15" at 850 idle. I think that's the best I am going to get it. The bouncing calmed down some too.
Old Jul 28, 2014 | 06:53 PM
BuzzLOL's Avatar
Car: '87 GTA Black/Black/Gold & others
Engine: TPI 350" & others
Transmission: Many
Axle/Gears: Many
. Your cam timing, pistons design, quench distance, and compression ratio will also affect vacuum...
Old Jul 28, 2014 | 08:52 PM
I think what I have it at now is pretty good. Got more vacuum out if it and it is steadier.
Old Jul 28, 2014 | 09:36 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Vacuum advance should be MANIFOLD or FULL vacuum advance and it should be limited to 10* @ 10 in/hg. Use either an adjustable can or a 1978 L82 corvette unit, probably listed at an autoparts house as a 350 with special high performance package.
IROCtometal
Sep 20, 2015 11:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
IROCtometal
Sep 2, 2015 02:01 PM
