Engine Timing with MSD Ignition
Old Jul 25, 2014 | 11:11 PM
1982Camaro383's Avatar
I have a 1982 Camaro below is my setup. I am trying to get the timing set correctly I have tried different advance curves. I still get pinging. Currently I have timing set to inital of 8 degrees with a 28 degree advance bushing with a total of 36 degrees of timing. I am getting pinging under load. Does anyone have a similar setup and found the correct timing curve and advance. Any help would be greatly appreciated.
Thanks in Advance,
Old Jul 26, 2014 | 12:49 AM
hellrazor's Avatar
Car: 82 Camaro Lots of mods
Engine: Blown 355
Axle/Gears: 3:73
Re: Engine Timing with MSD Ignition
What octane fuel are you running?
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Run 15 initial and 20 in the distributor for 35 total. What kind of gas? Might consider meth injection system too.
Old Jul 26, 2014 | 09:03 AM
I am running 93 octane. What about the springs I am currently using 2 light silver springs.
Thanks,
Justin
Last edited by 1982Camaro383; Jul 26, 2014 at 09:28 AM. Reason: Additional information
Old Jul 30, 2014 | 10:06 AM
cuisinartvette's Avatar
Car: 67 ******mobile
Engine: 385 Solid roller
Axle/Gears: 4.11
thatspart of your problem it may be coming in too much too soon.
Slower curve is better for the street
Try swapping a light out for a med go from there
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
djmarch
Aug 9, 2015 05:27 PM
