Random tach fluctuations at idle
Old Aug 13, 2014 | 12:11 AM
77chevymonster's Avatar
Car: 1987 IROC Z
So i have an 87 iroc z with a 305. Everything was fine up until a couple of months ago. The car now has what seems to be a very random misfire at idle only. I have changed the distributor cap, and rotor, plugs, and made sure the plug wires were connected well. I even tried to diagnose this random misfire by removing plug wires, it had no effect at all. I think it might be the coil, or an injector, but im not quite sure. Also i checked the resistance on each injector, and it was the same for all of them at 16.9 ohms i believe. As well as listened to the injectors to make sure they were opening.
Old Aug 13, 2014 | 12:25 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: Random tach fluctuations at idle
Could be anything in the ignition. ICM, coil, burnt plug wires, whatever.
IROCtometal
Sep 20, 2015 11:08 PM
TrevinE
Sep 14, 2015 03:20 PM
IROCtometal
Sep 9, 2015 10:01 AM
greenyone
Sep 8, 2015 08:41 PM
Jk_Under
Sep 8, 2015 08:13 AM
