cant pull codes
Old Aug 13, 2014 | 07:48 PM
aramirez121's Avatar
Car: 1991 camaro rs v6
Engine: v6 3.1
Transmission: auto
cant pull codes
i cant pull any codes from my ecc any have this problem
Old Aug 14, 2014 | 08:32 PM
tyeo098's Avatar
Car: 88 Chimera
Engine: 1994 LO5 5.7L
Axle/Gears: 2.73...?
Re: cant pull codes
Are you following the process exactly right?
Originally Posted by torque_is_good
the ALDL port (assembly line diagnostic link) is located above your right knee when you are in the drivers seat.
You want to take a paper clip and jumper the top 2 right pins together. Then, turn your key to "run" but do not start the car.
the CEL (check engine light) should blink once, and then twice which is code 12 or that it's in diag mode. It will do that 3 times and if there is another code, it will then flash the code such as blink 4 times and then 3 times. That is a code 43. it would do that 3 times. If there is another code it will then blink for that code. if there are no more codes, it will revert back to the 12 and blink that again
you then shut off the key, remove the paper clip and SEARCH for the codes as they have all been discussed many many many times on this as well as other sites. The newest 3rd gen is now 20 years old so feel confident that all the codes have been discussed exhaustively.
Old Aug 14, 2014 | 11:30 PM
Engine: v6 3.1
Transmission: auto
Re: cant pull codes
ive put an obd1 reader on it the inova reads other cars fine but not mine and i know there is something wrong especially when the CEL is on so im confused even took it to a shop they cant get anything
Old Aug 15, 2014 | 02:56 AM
Mayt13's Avatar
Car: 1989 Chevy Camaro IROC Z28
Axle/Gears: Stock
Re: cant pull codes
Might be a bad ecm. Go to pick a part and swap it out. How does it run?
Old Aug 15, 2014 | 05:07 AM
Engine: v6 3.1
Transmission: auto
Re: cant pull codes
runs great as far as i can tell
chazman
Aug 28, 2018 03:25 PM
86IROC112
Aug 31, 2015 07:00 AM
chazman
Aug 22, 2015 02:01 PM
GouldyGTR
Aug 21, 2015 10:43 PM
