camshaft abilities?
Old Aug 16, 2014 | 08:14 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
camshaft abilities?
I have these 2 camshafts and am wondering which is capable of 600hp, assuming they have heads intake etc..
Duration @ .05. Lift. Lobe sep.
In/ex. In/ex
248/251. 531/542. 106
255/265. 540/557. 106
Thx for your time and words.
Old Aug 18, 2014 | 09:36 PM
1gary's Avatar
Re: camshaft abilities?
In/ex. In/ex
This assumes a cam is a stand alone part and it isn't.Just to briefly say if your have the heads and intake isn't enough.A very common huge mistake.
Where the hell do you come up with a goal of 600hp??.
Old Aug 18, 2014 | 10:36 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Aahh i see a typo in my message. Assuming they have MATCHING heads, intake, etc..
Old Aug 19, 2014 | 07:19 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I'd say neither are capable of 600hp in a NA engine even if you did have matching heads, intake etc.
Old Aug 19, 2014 | 12:38 PM
1gary's Avatar
Once again.................there is more to it than that.
Old Aug 19, 2014 | 12:51 PM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Your limited information on those two cams tells very little about them.
Are they flat tappet? roller? hydraulic? solid?
What engine?
I will say this: Given only your parameters to design a cam within, whether solid or hydraulic roller, any engine builder worth his salt could make over 600 hp with either, without resorting to any exotic parts.
I'm making about 540 at a lowly 6400 rpm with a hydraulic cam far smaller than those. I could easily make more peak hp, but the stock PCM limits my shift points to 7100 rpm. I'm not the engine builder, but it's just a rebuilt stock-bottom LT1 350.
Old Aug 19, 2014 | 05:32 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Ok thanks alky and 86lg.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Elephantismo
Feb 13, 2019 12:51 AM
PurelyPMD
May 5, 2016 04:57 PM
88SS6SPEED
Nov 11, 2015 07:05 AM
GTAman
Sep 26, 2015 02:01 PM
