Well first official drive in years and we have an issue...
Old Aug 20, 2014 | 09:59 PM
acerocks666's Avatar
Car: 83' Z28 camaro
Engine: 5.7L 350
Transmission: TH350
Hey Everyone today I decided to take my 83 z28 on its first official drive to work in a few years. Up until today if I have driven it it has just been around home to test things out and check temps and such. First of all i want to say it starts first time every time and idles great. Oil pressure and engine temp have always been right at normal. So I hoped on the interstate and up until about 50mph it was fine then just did not want to go anymore. Lets just say after stopping 3 times I finally got off the last leg of my drive to work is 45 and under and it was fine rest of way. I decided to go through town on the way home and right at the last part of my drive on 45mph road it started to do it again I tried to give it gas and it initially would go then bog down and it actually ended up shutting down on me. Started right up again and I was able to get home fine. Right now the first thing I am thinking is that my exhaust is plugged up somewhere as this would be the first time it has really been driven since putting on my cat-back a few years ago. Just wanted to get some incite on other things it could maybe be get me headed in the right direction thanks for any help.....
Old Aug 24, 2014 | 07:37 PM
TylerSteez's Avatar
Car: 86 Trans Am WS6
Engine: 383 stroker
Re: Well first official drive in years and we have an issue...
Could be a clogged fuel filter or low fuel pressure, change the filter then rent a fuel pressure tester from autozone. Is it a tpi car or speed density? When my maf sensor was on it's way out whenever I'd give it gas it would bog down unless I feathered the throttle.
Vintageracer
Jan 10, 2020 05:33 PM
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
thefirebirdm@n
Sep 14, 2015 01:45 PM
jharrison5
Aug 19, 2015 05:53 PM
Fronzizzle
Aug 9, 2015 01:15 PM
